[PATCH 1/2] sb/setbuilder: Install the build when stagging or configured to install
Fri Sep 16 15:27:32 UTC 2022
Push it Chris.
On Fri, Sep 16, 2022, 10:01 AM Frank Kühndel <
frank.kuehndel at embedded-brains.de> wrote:
> Hi Chris,
> I checked your two patches in an opensuse leap 15.4 container building
> the tools (rtems-source-builder git) for RTEMS 6 and ARM BSP. The build
> was OK; the dependencies on "expat-devel" and "gmp-devel" are gone.
> Thanks and have a nice weekend
> Frank
> On 9/16/22 08:59, chrisj at rtems.org wrote:
> > Subject:
> > to install
> > From:
> > chrisj at rtems.org
> > Date:
> > 9/16/22, 08:59
> > To:
> > devel at rtems.org
> > From: Chris Johns<chrisj at rtems.org>
> >   source-builder/sb/setbuilder.py | 9 ++++++---
> >   1 file changed, 6 insertions(+), 3 deletions(-)
> > diff --git a/source-builder/sb/setbuilder.py
> b/source-builder/sb/setbuilder.py
> > index f24ac87..3e16111 100644
> > --- a/source-builder/sb/setbuilder.py
> > +++ b/source-builder/sb/setbuilder.py
> > @@ -226,6 +226,9 @@ class buildset:
> >       def installing(self):
> >           return self.install_mode() == 'installing'
> > +    def installable(self):
> > +        return not self.opts.no_install() or self.staging()
> >       def staging(self):
> >           return not self.installing()
> > @@ -553,14 +556,14 @@ class buildset:
> >                          ', '.join([b.name() for b in builds])))
> >               if deps is None and not have_errors:
> >                   for b in builds:
> > -                    log.trace('_bset:   : %s: %r' %
> (self.install_mode(),
> > -                                                     b.installable()))
> > +                    log.trace('_bset:   : %s: installable=%r
> build-installable=%r' % \
> > +                              (self.install_mode(), self.installable(),
> b.installable()))
> >                       if b.installable():
> >                           prefix = b.config.expand('%{_prefix}')
> >                           buildroot =
> path.join(b.config.expand('%{buildroot}'), prefix)
> >                           if self.staging():
> >                               prefix = b.config.expand('%{stagingroot}')
> > -                        if not self.opts.no_install():
> > +                        if self.installable():
> >                               self.install(self.install_mode(), b.name(),
> buildroot, prefix)
> >               # Sizes ...
> > -- 2.37.1 _______________________________________________ devel mailing
> > list devel at rtems.org http://lists.rtems.org/mailman/listinfo/devel
> embedded brains GmbH
> Herr Frank KÜHNDEL
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: frank.kuehndel at embedded-brains.de
> phone:  +49-89-18 94 741 - 23
> mobile: +49-176-15 22 06 - 11
> fax:    +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220916/91425f8b/attachment.htm>
