[PATCH] tftpDriver.c: Fix Coverity issues
Frank Kuehndel frank.kuehndel at embedded-brains.de
Fri Sep 16 17:13:32 UTC 2022
From: Frank Kühndel <frank.kuehndel at embedded-brains.de>
CID 1506523: Unchecked return value from library (CHECKED_RETURN)
CID 1506522: Unchecked return value from library (CHECKED_RETURN)
CID 1437618: Unchecked return value from library (CHECKED_RETURN)
Close #4718
 cpukit/libfs/src/ftpfs/tftpDriver.c | 27 ++++++++++++++++++++++-----
 1 file changed, 22 insertions(+), 5 deletions(-)
diff --git a/cpukit/libfs/src/ftpfs/tftpDriver.c b/cpukit/libfs/src/ftpfs/tftpDriver.c
index 59136ef59f..0246ed9611 100644
--- a/cpukit/libfs/src/ftpfs/tftpDriver.c
+++ b/cpukit/libfs/src/ftpfs/tftpDriver.c
@@ -525,8 +525,10 @@ static void send_error (
      * Send it
+     * Ignoring result because error packets are sent once and maybe lost.
-    sendto (tp->socket, (char *)&msg, len, 0, (struct sockaddr *)to, sizeof *to);
+    (void) sendto (tp->socket, (char *)&msg, len, 0, (struct sockaddr *)to, sizeof *to);
@@ -552,11 +554,21 @@ getPacket (struct tftpStream *tp, int retryCount)
     } else if (retryCount == 0) {
         tv.tv_sec = tp->config.first_timeout / 1000L;
         tv.tv_usec = (tp->config.first_timeout % 1000L) * 1000L;
-        setsockopt (tp->socket, SOL_SOCKET, SO_RCVTIMEO, &tv, sizeof tv);
+         * Ignoring result because all possible errors indicate wrong
+         * arguments and these arguments are OK as tested by test suite.
+        (void) setsockopt (tp->socket, SOL_SOCKET, SO_RCVTIMEO, &tv,
+            sizeof tv);
     } else {
         tv.tv_sec = tp->config.timeout / 1000L;
         tv.tv_usec = (tp->config.timeout % 1000L) * 1000L;
+            sizeof tv);
     for (;;) {
         union {
@@ -591,7 +603,12 @@ getPacket (struct tftpStream *tp, int retryCount)
     if (retryCount != GET_PACKET_DONT_WAIT) {
         tv.tv_sec = 0;
         tv.tv_usec = 0;
+            sizeof tv);
     return len;
@@ -724,7 +741,7 @@ static int process_data_packet (struct tftpStream *tp, ssize_t len)
          * Send it. Errors during send will not matter for this last ACK.
-        sendto (
+        (void) sendto (
             tp->socket,
             send_buf,
             plen,
2.35.3
