[PATCH v2 0/4] Microchip PolarFire SoC support
Alan Cudmore
alan.cudmore at gmail.com
Mon Sep 19 16:49:03 UTC 2022
Hi Padmarao,
The patches apply cleanly and build for me. What is the recommended
config.ini file for this BSP?
I used:
[riscv/mpfs64imafdc]
BUILD_TESTS=True
RTEMS_POSIX_API=True
RTEMS_SMP=True
BSP_START_COPY_FDT_FROM_U_BOOT=False
BSP_DTB_IS_SUPPORTED=True
BSP_DTB_HEADER_PATH=bsp/mpfs-dtb.h
I don't have a Polarfire SoC board, but is there a QEMU platform to run
this on?
When this is in, I will rebase my k210 variant and eventually get it
submitted!
Thanks,
Alan
On Mon, Sep 19, 2022 at 9:00 AM Padmarao Begari <
padmarao.begari at microchip.com> wrote:
> This patch set adds the Microchip PolarFire SoC BSP Variant
> support to RISC-V RTEMS.
> The PolarFire SoC is the 4x 64-bit RISC-V U54 cores and
> a 64-bit RISC-V E51 monitor core SoC from Microchip, more
> info available here:
> https://www.microchip.com/en-us/products/fpgas-and-plds/
> system-on-chip-fpgas/polarfire-soc-fpgas#Overview
> This new BSP variant is added for the 4x U54 cores not for E51
> because the E51 monitor core is resreved for first stage
> bootloader (Hart Software Services).
> The boot HARTID configurable is implemented for the riscv BSP
> to work with individual hart(cpu core) or SMP.
> This BSP support components: 4 CPU Cores (U54), Interrupt
> controller (PLIC), Timer (CLINT), UART (16550-compatible)
> work fine on actual Microchip PolarFire SoC Icicle Kit.
> v2:
> - Add a license and copyright information in dtb header file
> - Use RISCV_BOOT_HARDID instead of RTEMS_BOOT_HARDID
> - Add '_RISCV_Map_hardid_to_cpu_index()' and
> '_RISCV_Map_cpu_index_to_hardid()' functions
> - Change bsp_fdt_get() instead of bsp_fdt_copy() function for dtb
> - Move dtb and dtb header configurable build option to the bsps
> Padmarao Begari (4):
> bsps/riscv: Add device tree blob
> spec/build/bsps: Add dtb support
> bsps/riscv: Add Microchip PolarFire SoC BSP variant
> bsps/shared/: Use device tree blob
> bsps/riscv/riscv/clock/clockdrv.c | 6 +-
> bsps/riscv/riscv/config/mpfs64imafdc.cfg | 9 +
> bsps/riscv/riscv/dts/mpfs.dts | 365 +++++++++++
> bsps/riscv/riscv/include/bsp/mpfs-dtb.h | 602 ++++++++++++++++++
> bsps/riscv/riscv/include/bsp/riscv.h | 14 +
> bsps/riscv/riscv/irq/irq.c | 81 +++
> bsps/riscv/riscv/start/bsp_fatal_halt.c | 3 +
> bsps/riscv/riscv/start/bspsmp.c | 2 +-
> bsps/riscv/riscv/start/bspstart.c | 19 +-
> bsps/riscv/shared/start/start.S | 2 +
> bsps/shared/start/bsp-fdt.c | 8 +
> .../score/cpu/riscv/include/rtems/score/cpu.h | 2 +-
> .../cpu/riscv/include/rtems/score/cpuimpl.h | 2 +-
> spec/build/bsps/optdtb.yml | 19 +
> spec/build/bsps/optdtbheaderpath.yml | 20 +
> spec/build/bsps/riscv/optextirqmax.yml | 5 +-
> spec/build/bsps/riscv/optrambegin.yml | 5 +-
> spec/build/bsps/riscv/optramsize.yml | 5 +-
> spec/build/bsps/riscv/riscv/abi.yml | 6 +
> .../bsps/riscv/riscv/bspmpfs64imafdc.yml | 19 +
> spec/build/bsps/riscv/riscv/grp.yml | 6 +
> spec/build/bsps/riscv/riscv/optmpfs.yml | 18 +
> spec/build/bsps/riscv/riscv/optns16550max.yml | 3 +
> spec/build/cpukit/cpuopts.yml | 2 +
> spec/build/cpukit/optarchbits.yml | 1 +
> spec/build/cpukit/optboothartid.yml | 19 +
> spec/build/cpukit/optsmp.yml | 1 +
> 27 files changed, 1235 insertions(+), 9 deletions(-)
> create mode 100644 bsps/riscv/riscv/config/mpfs64imafdc.cfg
> create mode 100644 bsps/riscv/riscv/dts/mpfs.dts
> create mode 100644 bsps/riscv/riscv/include/bsp/mpfs-dtb.h
> create mode 100644 spec/build/bsps/optdtb.yml
> create mode 100644 spec/build/bsps/optdtbheaderpath.yml
> create mode 100644 spec/build/bsps/riscv/riscv/bspmpfs64imafdc.yml
> create mode 100644 spec/build/bsps/riscv/riscv/optmpfs.yml
> create mode 100644 spec/build/cpukit/optboothartid.yml
> 2.25.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220919/8cfeacce/attachment.htm>
