[PATCH] sb/set-builder: Fix staging and tar file generation with a single config build
Thu Sep 29 11:50:42 UTC 2022
On 29/9/22 9:45 pm, Christian MAUDERER wrote:
> Hello Chris,
> thanks for the quick patch. With this qemu and microblaze work again like expected.
> I tested all tools starting with devel/* and from the ones that work only
> devel/autotools-internal didn't generate a tar archive. But that one has a
> comment "Do not use via the command line" in the bset file so that is most
> likely fine.
> Some of other devel/* packages didn't build in my test setup, but I have never
> tested or used them before so that is probably a problem of my build environment
> or maybe a known bug.
Thanks for the testing. I will push to the devel branch and 5.
