[PATCH] sb/set-builder: Fix staging and tar file generation with a single config build
Fri Sep 30 03:49:54 UTC 2022
On 29/9/2022 9:50 pm, Chris Johns wrote:
> On 29/9/22 9:45 pm, Christian MAUDERER wrote:
>> Hello Chris,
>> thanks for the quick patch. With this qemu and microblaze work again like expected.
>> I tested all tools starting with devel/* and from the ones that work only
>> devel/autotools-internal didn't generate a tar archive. But that one has a
>> comment "Do not use via the command line" in the bset file so that is most
>> likely fine.
>> Some of other devel/* packages didn't build in my test setup, but I have never
>> tested or used them before so that is probably a problem of my build environment
>> or maybe a known bug.
> Thanks for the testing. I will push to the devel branch and 5.
Tarfile creation is working however installing is not. I am working on fixing this.
