[PATCH] wscript: Deduplicate installed files
Mon Feb 6 06:55:43 UTC 2023
On 06.02.23 03:35, Chris Johns wrote:
> On 4/2/2023 6:11 am, Sebastian Huber wrote:
>> On 03.02.23 19:45, Kinsey Moore wrote:
>>> This is my first stab at solving this duplicate install problem. I could
>>> manually solve the problem by deduplicating the object includes and moving it
>>> up to the BSP, but that is less intuitive since these drivers both depend on
>>> the same code and the BSP doesn't depend on it directly.
>> Why don't you add the shared stuff to a objxilcommon.yml?
>> The approach in the wscript is a bit complex from my point of view.
> I am OK with adding this code or something similar. It is no more complex than
> other places I have reviewed, eg `Item._init_link()`.
> The issue is currently not easy to see and may be present in other places
> without us knowing. I am also fine with a spec file check that highlights a
> clash to draw attention to a problem when the spec files are parsed. I feeling
> we need something.
If you install with
./waf install -vv
you see the duplicate install targets. See also
https://gitlab.com/ita1024/waf/-/issues/2329#note_467849523
Before we add double for loops we should first analyze the underlying
problem. In this case it is a diamond shaped build dependency graph.
spec/build/bsps/objnandpsu.yml:  uid: objxilinxsupport
spec/build/bsps/objqspipsu.yml:  uid: objxilinxsupport
spec/build/bsps/aarch64/xilinx-zynqmp/objjffs2qspinor.yml:  uid:
../../objqspipsu
spec/build/bsps/aarch64/xilinx-zynqmp/grp_zu3eg.yml:  uid: ../../objnandpsu
In addition to the duplicate install targets you build also the objects
of objxilinxsupport twice and add them to the library.
I would simply move the links to grp_zu3eg:
grp_zu3eg.yml:  uid: ../../objxilinxspport
grp_zu3eg.yml:  uid: ../../objqspipsu
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
