[patch] medit issue
    zack leung
    zakthertemsdev at gmail.com
    Sat Feb 11 02:35:23 UTC 2023
libmisc/shell: User can't cut using ctrl e and x in medit
Closes #4557
 cpukit/libmisc/shell/main_edit.c | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/cpukit/libmisc/shell/main_edit.c
b/cpukit/libmisc/shell/main_edit.c
index 6e954639e2..8317452b7b 100644
--- a/cpukit/libmisc/shell/main_edit.c
+++ b/cpukit/libmisc/shell/main_edit.c
@@ -1713,7 +1713,6 @@ static void copy_selection(struct editor *ed) {
   ed->env->clipboard = (unsigned char *) realloc(ed->env->clipboard,
ed->env->clipsize);
   if (!ed->env->clipboard) return;
   copy(ed, ed->env->clipboard, selstart, ed->env->clipsize);
-  select_toggle(ed);
 static void cut_selection(struct editor *ed) {
@@ -2132,7 +2131,7 @@ static void edit(struct editor *ed) {
         case ctrl('e'): select_toggle(ed); break;
         case ctrl('a'): select_all(ed); break;
-        case ctrl('c'): copy_selection(ed); break;
+        case ctrl('c'): copy_selection(ed);select_toggle(ed); break;
         case ctrl('f'): find_text(ed, 0); break;
         case ctrl('l'): goto_line(ed); break;
         case ctrl('g'): find_text(ed, 1); break;
2.39.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230210/f3586c7a/attachment-0001.htm>
