Risc-v failures Fwd: [rtems-bsp-builder] 2023-02-12 05:13:18: Profile(s): everything
Mon Feb 13 14:31:30 UTC 2023
This is a longer reply than necessary hoping others read it and
remember these details about the RTEMS testing setup. :)
On Mon, Feb 13, 2023, 3:12 AM Hesham Almatary <heshamelmatary at gmail.com>
wrote:
> Hello Joel,
> There shouldn't be any BSP with "medany" name in it. Where's the build
> script? I tried to fix your build in the cron script [1] but not sure
> if you use "medany" anywhere else.
The rtems-bsp-builder is driven by the configuration files in this
directory:
https://git.rtems.org/rtems-tools/tree/config
BSP tiers are defined in the User Guide although I wonder if this is really
more of something that should be in the Software Engineering Guide.
https://docs.rtems.org/branches/master/user/hardware/tiers.html
The BSPs in the tier files are placed there by hand. It is a conscious
decision. It is arguable that anything in my rtems-cron-helpers with
good results is in Tier 2. I don't think we have a Tier 1 which is
REGULARLY reported although we have BSPs we all would accept
as Tier 1. Most are Tier 3 because we can build but not test. Tier 4
status is usually transitory.
*** The list of files in rtems-bsps-riscv* must be out of date.
That also makes me wonder what else is out of date there. I made
a pass a few months ago but if you can script checking what rtems-bsps
reports versus what's in each rtems-bsps-CPU.ini, that would be helpful.
I think long term Chris wanted the BSP builder to get them from rtems
itself on the fly.
> [1] https://github.com/joelsherrill/rtems-cron-helpers/pulls
> On Sun, 12 Feb 2023 at 18:12, Joel Sherrill <joel at rtems.org> wrote:
> > Hi
> > Looks like after Karel's fix goes in, the failures to build are all
> risc-v bsps. They show up on the Ubuntu and Freebsd build reports but are
> likely everywhere but the other hosts haven't rotated around yet.
> > Hesham.. could you kindly please try to resolve those?
> > Thanks
> > ---------- Forwarded message ---------
> > From: OAR Tester for FreeBSD 12 <rtems-tester at oarcorp.com>
> > Date: Sun, Feb 12, 2023, 11:50 AM
> > Subject: [rtems-bsp-builder] 2023-02-12 05:13:18: Profile(s): everything
> > To: <build at rtems.org>
> > RTEMS Tools Project - RTEMS Kernel BSP Builder, 6.0.not_released
> > Host: FreeBSD 12.3-RELEASE-p6 GENERIC
> > command: /home/tester/rtems-cron-6/tools/6/bin/rtems-bsp-builder\
> >          --rtems=/home/tester/rtems-cron-6/rtems
> --build-path=/home/tester\
> >          /rtems-cron-6/build --prefix=/home/tester/rtems-\
> >          cron-6/tools/6/bsps --log=/home/tester/rtems-cron-6/bsp-\
> >          builder.log --warnings-report=warnings.log --mail
> --use-gitconfig\
> >          --profiles=everything
> > Total Time            : 6:36:35.332796 for 1282 completed job(s)
> > Average BSP Build Time: 0:00:18.561102
> > Builds
> >  debug
> >  no-posix
> >  posix
> >  posix-debug
> >  posix-profiling
> >  profiling
> >  smp
> >  smp-debug
> > Failures Report
> >    1 debug arm/stm32h757i-eval-m4 build:
> >       configure: /home/tester/rtems-cron-6/rtems/waf configure\
> >       --prefix=/home/tester/rtems-cron-6/tools/6/bsps --top=/home/tester\
> >       /rtems-cron-6/rtems --rtems-config=config-arm-stm32h757i-\
> >       eval-m4-debug.ini
> >      error: bsps/arm/stm32h7/boards/stm/stm32h757i-
> >             eval/stm32h7-bspstarthooks.c:39:10: fatal error:
> >             stm32h747i_eval_qspi.h: No such file or directory
> >    2 no-posix arm/stm32h757i-eval-m4 build:
> >       /rtems-cron-6/rtems
> --rtems-config=config-arm-stm32h757i-eval-m4-no-\
> >       posix.ini
> >    3 posix arm/stm32h757i-eval-m4 build:
> >       eval-m4-posix.ini
> >    4 posix-debug arm/stm32h757i-eval-m4 build:
> >       /rtems-cron-6/rtems --rtems-config=config-arm-stm32h757i-eval-m4\
> >       -posix-debug.ini
> >    5 posix-profiling arm/stm32h757i-eval-m4 build:
> >       -posix-profiling.ini
> >    6 profiling arm/stm32h757i-eval-m4 build:
> >       eval-m4-profiling.ini
> >    7 debug riscv/rv64imac_medany configure:
> >       /rtems-cron-6/rtems --rtems-config=config-riscv-rv64imac_medany-\
> >       debug.ini
> >    8 no-posix riscv/rv64imac_medany configure:
> >       /rtems-cron-6/rtems
> --rtems-config=config-riscv-rv64imac_medany-no-\
> >       posix.ini
> >    9 posix riscv/rv64imac_medany configure:
> >       posix.ini
> >   10 posix-debug riscv/rv64imac_medany configure:
> >       posix-debug.ini
> >   11 posix-profiling riscv/rv64imac_medany configure:
> >       posix-profiling.ini
> >   12 profiling riscv/rv64imac_medany configure:
> >       profiling.ini
> >   13 smp riscv/rv64imac_medany configure:
> >       smp.ini
> >   14 smp-debug riscv/rv64imac_medany configure:
> >       /rtems-cron-6/rtems
> --rtems-config=config-riscv-rv64imac_medany-smp-\
> >       debug.ini
> >   15 debug riscv/rv64imafd_medany configure:
> >       /rtems-cron-6/rtems --rtems-config=config-riscv-rv64imafd_medany-\
> >       debug.ini
> >   16 no-posix riscv/rv64imafd_medany configure:
> >       /rtems-cron-6/rtems
> --rtems-config=config-riscv-rv64imafd_medany-no-\
> >       posix.ini
> >   17 posix riscv/rv64imafd_medany configure:
> >       posix.ini
> >   18 posix-debug riscv/rv64imafd_medany configure:
> >       posix-debug.ini
> >   19 posix-profiling riscv/rv64imafd_medany configure:
> >       posix-profiling.ini
> >   20 profiling riscv/rv64imafd_medany configure:
> >       profiling.ini
> >   21 smp riscv/rv64imafd_medany configure:
> >       smp.ini
> >   22 smp-debug riscv/rv64imafd_medany configure:
> >       smp-debug.ini
> >   23 debug riscv/rv64imafdc_medany configure:
> >       /rtems-cron-6/rtems --rtems-config=config-riscv-rv64imafdc_medany-\
> >       debug.ini
> >   24 no-posix riscv/rv64imafdc_medany configure:
> >       no-posix.ini
> >   25 posix riscv/rv64imafdc_medany configure:
> >       posix.ini
> >   26 posix-debug riscv/rv64imafdc_medany configure:
> >       posix-debug.ini
> >   27 posix-profiling riscv/rv64imafdc_medany configure:
> >       posix-profiling.ini
> >   28 profiling riscv/rv64imafdc_medany configure:
> >       profiling.ini
> >   29 smp riscv/rv64imafdc_medany configure:
> >       smp.ini
> >   30 smp-debug riscv/rv64imafdc_medany configure:
> >       smp-debug.ini
> > Warnings Report
> >  | By Architecture (total : 10477)                                     |
> >  | common : 14 warning(s)                                              |
> >  |   Shared :  738 |     BSP :    0 | Network :    0 |    Tests :    0 |
> >  |   LibCPU :    0 | CPU Kit :  168 |                |                 |
> >  | aarch64 : 21 warning(s)                                             |
> >  |   Shared :    3 |     BSP :    0 | Network :    0 |    Tests :    0 |
> >  |   LibCPU :    0 | CPU Kit :  532 |                |                 |
> >  | arm : 34 warning(s)                                                 |
> >  |   Shared :  192 |     BSP :    0 | Network :    0 |    Tests :    0 |
> >  |   LibCPU :    0 | CPU Kit :  202 |                |                 |
> >  | bfin : 32 warning(s)                                                |
> >  |   Shared :  138 |     BSP :    0 | Network :    0 |    Tests :    0 |
> >  |   LibCPU :  234 | CPU Kit :   90 |                |                 |
> >  | i386 : 31 warning(s)                                                |
> >  |   Shared :    0 |     BSP :    0 | Network :    0 |    Tests :    0 |
> >  |   LibCPU :    0 | CPU Kit :   60 |                |                 |
> >  | lm32 : 14 warning(s)                                                |
> >  |   Shared :  156 |     BSP :    0 | Network :    0 |    Tests :    0 |
> >  |   LibCPU :    0 | CPU Kit :   72 |                |                 |
> >  | m68k : 33 warning(s)                                                |
> >  |   Shared :  936 |     BSP :    0 | Network :    0 |    Tests :    0 |
> >  |   LibCPU :    0 | CPU Kit :  330 |                |                 |
> >  | microblaze : 1 warning(s)                                           |
> >  |   Shared :   36 |     BSP :    0 | Network :    0 |    Tests :    0 |
> >  |   LibCPU :    0 | CPU Kit :    0 |                |                 |
> >  | mips : 8 warning(s)                                                 |
> >  |   LibCPU :    0 | CPU Kit :   24 |                |                 |
> >  | moxie : 2 warning(s)                                                |
> >  |   Shared :   12 |     BSP :    0 | Network :    0 |    Tests :    0 |
> >  |   LibCPU :    0 | CPU Kit :   18 |                |                 |
> >  | nios2 : 0 warning(s)                                                |
> >  | or1k : 1 warning(s)                                                 |
> >  |   Shared :    6 |     BSP :    0 | Network :    0 |    Tests :    0 |
> >  | powerpc : 25 warning(s)                                             |
> >  |   Shared :  140 |     BSP :    0 | Network :    0 |    Tests :    0 |
> >  |   LibCPU :   12 | CPU Kit :  218 |                |                 |
> >  | sh : 162 warning(s)                                                 |
> >  |   Shared :   84 |     BSP :    0 | Network :    0 |    Tests :    0 |
> >  |   LibCPU :    0 | CPU Kit :   84 |                |                 |
> >  | sparc : 4 warning(s)                                                |
> >  | sparc64 : 2 warning(s)                                              |
> >  | v850 : 1 warning(s)                                                 |
> >  |   Shared :   72 |     BSP :    0 | Network :    0 |    Tests :    0 |
> >  |   LibCPU :    0 | CPU Kit :   36 |                |                 |
> >  | x86_64 : 1 warning(s)                                               |
> >  |   LibCPU :    0 | CPU Kit :    6 |                |                 |
> >  | By BSP (total : 10477)                                              |
> >  | common : 291 warning(s)                                             |
> >  |   Shared : 1557 |     BSP :    0 | Network :    0 |    Tests :    0 |
> >  |   LibCPU :   96 | CPU Kit : 1300 |                |                 |
> >  | aarch64/a53_ilp32_qemu : 0 warning(s)                               |
> >  | aarch64/a72_ilp32_qemu : 0 warning(s)                               |
> >  | aarch64/xilinx_zynqmp_ilp32_qemu : 0 warning(s)                     |
> >  | aarch64/xilinx_zynqmp_ilp32_zu3eg : 1 warning(s)                    |
> >  |   Shared :    2 |     BSP :    0 | Network :    0 |    Tests :    0 |
> >  |   LibCPU :    0 | CPU Kit :  152 |                |                 |
> >  | arm/altcycv_devkit : 7 warning(s)                                   |
> >  | arm/atsamv : 6 warning(s)                                           |
> >  | arm/beagleboardorig : 0 warning(s)                                  |
> >  | arm/beagleboardxm : 0 warning(s)                                    |
> >  | arm/beagleboneblack : 0 warning(s)                                  |
> >  | arm/beaglebonewhite : 0 warning(s)                                  |
> >  | arm/csb336 : 0 warning(s)                                           |
> >  | arm/csb337 : 0 warning(s)                                           |
> >  | arm/csb637 : 0 warning(s)                                           |
> >  | arm/gumstix : 0 warning(s)                                          |
> >  | arm/imx7 : 2 warning(s)                                             |
> >  |   LibCPU :    0 | CPU Kit :   32 |                |                 |
> >  | arm/imxrt1052 : 0 warning(s)                                        |
> >  | arm/kit637_v6 : 0 warning(s)                                        |
> >  | arm/lm3s3749 : 0 warning(s)                                         |
> >  | arm/lm3s6965 : 0 warning(s)                                         |
> >  | arm/lm3s6965_qemu : 0 warning(s)                                    |
> >  | arm/lm4f120 : 0 warning(s)                                          |
> >  | arm/lpc1768_mbed : 0 warning(s)                                     |
> >  | arm/lpc1768_mbed_ahb_ram : 0 warning(s)                             |
> >  | arm/lpc1768_mbed_ahb_ram_eth : 0 warning(s)                         |
> >  | arm/lpc17xx_ea_ram : 0 warning(s)                                   |
> >  | arm/lpc17xx_ea_rom_int : 0 warning(s)                               |
> >  | arm/lpc17xx_plx800_ram : 0 warning(s)                               |
> >  | arm/lpc17xx_plx800_rom_int : 0 warning(s)                           |
> >  | arm/lpc2362 : 0 warning(s)                                          |
> >  | arm/lpc23xx_tli800 : 0 warning(s)                                   |
> >  | arm/lpc24xx_ea : 0 warning(s)                                       |
> >  | arm/lpc24xx_ncs_ram : 0 warning(s)                                  |
> >  | arm/lpc24xx_ncs_rom_ext : 0 warning(s)                              |
> >  | arm/lpc24xx_ncs_rom_int : 0 warning(s)                              |
> >  | arm/lpc24xx_plx800_ram : 0 warning(s)                               |
> >  | arm/lpc24xx_plx800_rom_int : 0 warning(s)                           |
> >  | arm/lpc32xx_mzx : 0 warning(s)                                      |
> >  | arm/lpc32xx_mzx_stage_1 : 0 warning(s)                              |
> >  | arm/lpc32xx_mzx_stage_2 : 0 warning(s)                              |
> >  | arm/lpc32xx_phycore : 0 warning(s)                                  |
> >  | arm/lpc40xx_ea_ram : 0 warning(s)                                   |
> >  | arm/lpc40xx_ea_rom_int : 0 warning(s)                               |
> >  | arm/nucleo-h743zi : 0 warning(s)                                    |
> >  | arm/raspberrypi : 0 warning(s)                                      |
> >  | arm/raspberrypi2 : 0 warning(s)                                     |
> >  | arm/realview_pbx_a9_qemu : 0 warning(s)                             |
> >  | arm/smdk2410 : 0 warning(s)                                         |
> >  | arm/stm32f105rc : 0 warning(s)                                      |
> >  | arm/stm32f4 : 2 warning(s)                                          |
> >  | arm/stm32h7 : 0 warning(s)                                          |
> >  | arm/stm32h747i-disco : 0 warning(s)                                 |
> >  | arm/stm32h747i-disco-m4 : 0 warning(s)                              |
> >  | arm/stm32h757i-eval : 0 warning(s)                                  |
> >  | arm/stm32h757i-eval-m4 : 0 warning(s)                               |
> >  | arm/stm32h7b3i-dk : 0 warning(s)                                    |
> >  | arm/xilinx_zynqmp_ultra96 : 1 warning(s)                            |
> >  | bfin/TLL6527M : 11 warning(s)                                       |
> >  |   Shared :   42 |     BSP :    0 | Network :    0 |    Tests :    0 |
> >  |   LibCPU :  138 | CPU Kit :   30 |                |                 |
> >  | bfin/bf537Stamp : 0 warning(s)                                      |
> >  | bfin/eZKit533 : 0 warning(s)                                        |
> >  | i386/pc386 : 0 warning(s)                                           |
> >  | i386/pc486 : 0 warning(s)                                           |
> >  | i386/pc586 : 0 warning(s)                                           |
> >  | i386/pc586-sse : 0 warning(s)                                       |
> >  | i386/pc686 : 0 warning(s)                                           |
> >  | i386/pcp4 : 0 warning(s)                                            |
> >  | lm32/lm32_evr : 0 warning(s)                                        |
> >  | lm32/lm32_evr_gdbsim : 0 warning(s)                                 |
> >  | lm32/milkymist : 12 warning(s)                                      |
> >  |   Shared :   96 |     BSP :    0 | Network :    0 |    Tests :    0 |
> >  | m68k/COBRA5475 : 0 warning(s)                                       |
> >  | m68k/av5282 : 0 warning(s)                                          |
> >  | m68k/csb360 : 0 warning(s)                                          |
> >  | m68k/gen68340 : 0 warning(s)                                        |
> >  | m68k/gen68360 : 2 warning(s)                                        |
> >  |   Shared :   18 |     BSP :    0 | Network :    0 |    Tests :    0 |
> >  |   LibCPU :    0 | CPU Kit :   12 |                |                 |
> >  | m68k/gen68360_040 : 0 warning(s)                                    |
> >  | m68k/m5484FireEngine : 3 warning(s)                                 |
> >  |   Shared :   66 |     BSP :    0 | Network :    0 |    Tests :    0 |
> >  | m68k/mcf5206elite : 1 warning(s)                                    |
> >  |   Shared :   78 |     BSP :    0 | Network :    0 |    Tests :    0 |
> >  | m68k/mcf52235 : 3 warning(s)                                        |
> >  | m68k/mcf5225x : 3 warning(s)                                        |
> >  | m68k/mcf5235 : 1 warning(s)                                         |
> >  | m68k/mcf5329 : 3 warning(s)                                         |
> >  | m68k/mrm332 : 0 warning(s)                                          |
> >  | m68k/mvme147 : 0 warning(s)                                         |
> >  | m68k/mvme147s : 0 warning(s)                                        |
> >  | m68k/mvme162 : 0 warning(s)                                         |
> >  | m68k/mvme162lx : 0 warning(s)                                       |
> >  | m68k/mvme167 : 0 warning(s)                                         |
> >  | m68k/pgh360 : 0 warning(s)                                          |
> >  | m68k/uC5282 : 6 warning(s)                                          |
> >  | microblaze/kcu105 : 0 warning(s)                                    |
> >  | microblaze/kcu105_qemu : 0 warning(s)                               |
> >  | mips/hurricane : 1 warning(s)                                       |
> >  | mips/malta : 6 warning(s)                                           |
> >  | mips/rbtx4938 : 1 warning(s)                                        |
> >  | moxie/moxiesim : 2 warning(s)                                       |
> >  | nios2/nios2_iss : 0 warning(s)                                      |
> >  | or1k/generic_or1k : 1 warning(s)                                    |
> >  | powerpc/beatnik : 2 warning(s)                                      |
> >  |   LibCPU :   12 | CPU Kit :    4 |                |                 |
> >  | powerpc/br_uid : 0 warning(s)                                       |
> >  | powerpc/gwlcfm : 0 warning(s)                                       |
> >  | powerpc/hsc_cm01 : 0 warning(s)                                     |
> >  | powerpc/icecube : 0 warning(s)                                      |
> >  | powerpc/mcp750 : 0 warning(s)                                       |
> >  | powerpc/mpc5566evb : 0 warning(s)                                   |
> >  | powerpc/mpc5643l_evb : 0 warning(s)                                 |
> >  | powerpc/mpc5668g : 0 warning(s)                                     |
> >  | powerpc/mpc5674fevb : 0 warning(s)                                  |
> >  | powerpc/mpc8260ads : 0 warning(s)                                   |
> >  | powerpc/mpc8309som : 0 warning(s)                                   |
> >  | powerpc/mpc8313erdb : 0 warning(s)                                  |
> >  | powerpc/mpc8349eamds : 0 warning(s)                                 |
> >  | powerpc/mtx603e : 0 warning(s)                                      |
> >  | powerpc/mvme2100 : 0 warning(s)                                     |
> >  | powerpc/mvme2307 : 0 warning(s)                                     |
> >  | powerpc/mvme3100 : 1 warning(s)                                     |
> >  |   LibCPU :    0 | CPU Kit :    4 |                |                 |
> >  | powerpc/mvme5500 : 2 warning(s)                                     |
> >  | powerpc/pghplus : 0 warning(s)                                      |
> >  | powerpc/phycore_mpc5554 : 0 warning(s)                              |
> >  | powerpc/pm520_cr825 : 0 warning(s)                                  |
> >  | powerpc/pm520_ze30 : 0 warning(s)                                   |
> >  | powerpc/psim : 1 warning(s)                                         |
> >  | powerpc/qemuppc : 1 warning(s)                                      |
> >  | powerpc/qemuprep : 0 warning(s)                                     |
> >  | powerpc/qemuprep-altivec : 0 warning(s)                             |
> >  | powerpc/qoriq_core_0 : 0 warning(s)                                 |
> >  | powerpc/qoriq_core_1 : 0 warning(s)                                 |
> >  | powerpc/qoriq_e500 : 0 warning(s)                                   |
> >  | powerpc/qoriq_e6500_32 : 0 warning(s)                               |
> >  | powerpc/qoriq_e6500_64 : 4 warning(s)                               |
> >  |   Shared :   24 |     BSP :    0 | Network :    0 |    Tests :    0 |
> >  |   LibCPU :    0 | CPU Kit :   30 |                |                 |
> >  | powerpc/ss555 : 2 warning(s)                                        |
> >  | powerpc/t32mppc : 2 warning(s)                                      |
> >  |   LibCPU :    0 | CPU Kit :   40 |                |                 |
> >  | powerpc/tqm8xx_stk8xx : 0 warning(s)                                |
> >  | powerpc/virtex : 0 warning(s)                                       |
> >  | powerpc/virtex4 : 0 warning(s)                                      |
> >  | powerpc/virtex5 : 0 warning(s)                                      |
> >  | sh/gensh1 : 1 warning(s)                                            |
> >  | sh/gensh2 : 1 warning(s)                                            |
> >  | sh/gensh4 : 1 warning(s)                                            |
> >  | sh/simsh1 : 0 warning(s)                                            |
> >  | sh/simsh2 : 0 warning(s)                                            |
> >  | sh/simsh2e : 0 warning(s)                                           |
> >  | sh/simsh4 : 0 warning(s)                                            |
> >  | sparc/at697f : 0 warning(s)                                         |
> >  | sparc/gr712rc : 0 warning(s)                                        |
> >  | sparc/gr740 : 0 warning(s)                                          |
> >  | sparc/leon2 : 0 warning(s)                                          |
> >  | sparc/leon3 : 0 warning(s)                                          |
> >  | sparc/ut699 : 0 warning(s)                                          |
> >  | sparc/ut700 : 0 warning(s)                                          |
> >  | sparc64/niagara : 0 warning(s)                                      |
> >  | sparc64/usiii : 1 warning(s)                                        |
> >  | v850/v850e1sim : 0 warning(s)                                       |
> >  | v850/v850e2sim : 0 warning(s)                                       |
> >  | v850/v850e2v3sim : 0 warning(s)                                     |
> >  | v850/v850esim : 0 warning(s)                                        |
> >  | v850/v850essim : 0 warning(s)                                       |
> >  | v850/v850sim : 0 warning(s)                                         |
> >  | x86_64/amd64 : 1 warning(s)                                         |
> >  | By Build (total : 10477)                                            |
> >  | common : 381 warning(s)                                             |
> >  |   Shared : 1491 |     BSP :    0 | Network :    0 |    Tests :    0 |
> >  |   LibCPU :  205 | CPU Kit : 1574 |                |                 |
> >  | debug : 5 warning(s)                                                |
> >  |   Shared :  296 |     BSP :    0 | Network :    0 |    Tests :    0 |
> >  |   LibCPU :   41 | CPU Kit :  324 |                |                 |
> >  | no-posix : 0 warning(s)                                             |
> >  | posix-debug : 0 warning(s)                                          |
> >  | posix-profiling : 0 warning(s)                                      |
> >  | smp : 0 warning(s)                                                  |
> >  | smp-debug : 0 warning(s)                                            |
> > build mailing list
> > build at rtems.org
> > http://lists.rtems.org/mailman/listinfo/build
> Regards,
> Hesham
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230213/5884408e/attachment-0001.htm>
