Build failures on CentOS 8
Chris Johns
chrisj at rtems.org
Wed Feb 15 22:31:59 UTC 2023
On 16/2/2023 8:43 am, Jeff Mayes wrote:
> We’re getting an odd build failure on CentOS 8. (I know it’s EOL.) Below is a
> snip of the output. Any ideas?
Are you able to run a test with the latest version of waf?
You can download it here https://waf.io/waf-2.0.25 (https://waf.io/) and simply
replace the `waf` file in our top level with it. You will need to `distclean
configure ...` once replaced.
