Build failures on CentOS 8
Jeff Mayes
Jeff.Mayes at OARcorp.com
Thu Feb 16 14:57:53 UTC 2023
>>On 16/2/2023 8:43 am, Jeff Mayes wrote:
>> We?re getting an odd build failure on CentOS 8. (I know it?s EOL.)
>> ?Below is a snip of the output.? Any ideas?
>Are you able to run a test with the latest version of waf?
>You can download it here https://waf.io/waf-2.0.25 (https://waf.io/) and simply replace the `waf` file in our top level with it. You will need to `distclean configure ...` once replaced.
>Chris
Yes. That did the trick.
Thanks!
