[PATCH rtems-source-builder 1/2] Update to gdb 13.1 for rtems 6
Joel Sherrill
joel at rtems.org
Wed Feb 22 15:26:40 UTC 2023
Is it ok to push if I fix the comment?
--joel
On Wed, Feb 22, 2023 at 3:29 AM Frank Kühndel <
frank.kuehndel at embedded-brains.de> wrote:
> Hello Joel,
> On 2/21/23 16:25, Joel Sherrill wrote:
> > Subject:
> > From:
> > Joel Sherrill <joel at rtems.org>
> > Date:
> > 2/21/23, 16:25
> > To:
> > devel at rtems.org
> > rtems/config/6/rtems-default.bset | 2 +-
> > rtems/config/tools/rtems-gdb-13.1.cfg | 16 ++++++++++++++++
> > 2 files changed, 17 insertions(+), 1 deletion(-)
> > create mode 100644 rtems/config/tools/rtems-gdb-13.1.cfg
> > diff --git a/rtems/config/6/rtems-default.bset
> b/rtems/config/6/rtems-default.bset
> > index a0601aa..a76efe6 100644
> > --- a/rtems/config/6/rtems-default.bset
> > +++ b/rtems/config/6/rtems-default.bset
> > @@ -12,7 +12,7 @@
> > %defineifnot with_rtems_dtc devel/dtc-1.6.1-1
> > %defineifnot with_rtems_expat devel/expat-2.4.8-1
> > %defineifnot with_rtems_gmp devel/gmp-6.2.1
> > -%defineifnot with_rtems_gdb tools/rtems-gdb-12.1
> > +%defineifnot with_rtems_gdb tools/rtems-gdb-13.1
> > %defineifnot with_rtems_binutils tools/rtems-binutils-2.38
> > %defineifnot with_rtems_gcc tools/rtems-gcc-12-newlib-head
> > %defineifnot with_rtems_tools tools/rtems-tools-6
> > diff --git a/rtems/config/tools/rtems-gdb-13.1.cfg
> b/rtems/config/tools/rtems-gdb-13.1.cfg
> > new file mode 100644
> > index 0000000..4a6a1c7
> > --- /dev/null
> > +++ b/rtems/config/tools/rtems-gdb-13.1.cfg
> > @@ -0,0 +1,16 @@
> > +# GDB 12.1
> Is 12.1 correct? It looks like a copy-paste error.
> Greetings
> Frank
> > +%include %{_configdir}/checks.cfg
> > +%include %{_configdir}/base.cfg
> > +%define gdb_version 13.1
> > +%define gdb_src_ext xz
> > +%hash sha512 gdb-%{gdb_version}.tar.xz \
> 5lBU/7wDV+7tSxfh7cXvRapzyd3zsSEGUePYWVduJ8HSeyZoAP4mMo7aWIV0VczYYy9AAM/F9j+QhUCWKQGHyg==
> > +#%patch add gdb --rsb-file=gdb-readline8.2.patchhttps://
> sourceware.org/git/?p=binutils-gdb.git;a=commitdiff_plain;h=1add37b567a7dee39d99f37b37802034c3fce9c4
> > +#%hash sha512 gdb-readline8.2.patch
> E/nGalfBBfn0rl/pi1SGIuKD11x0qREZBp3ajaFbl/nGMZUIm31M/1z0FsG76K7IjvE5pPsl2JqESt+LBN9lZA==
> > +%include %{_configdir}/gdb-common-1.cfg
> > -- 2.24.4 _______________________________________________ devel mailing
> > list devel at rtems.org http://lists.rtems.org/mailman/listinfo/devel
> embedded brains GmbH
> Herr Frank KÜHNDEL
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: frank.kuehndel at embedded-brains.de
> phone: +49-89-18 94 741 - 23
> mobile: +49-176-15 22 06 - 11
> fax: +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230222/b510918b/attachment.htm>
