[PATCH rtems-source-builder 1/2] Update to gdb 13.1 for rtems 6
    Frank Kühndel
    frank.kuehndel at embedded-brains.de
    Wed Feb 22 15:40:06 UTC 2023
On 2/22/23 16:26, Joel Sherrill wrote:
> Is it ok to push if I fix the comment?
I confess I have not tried your patch. I noted you have commented out
the gdb-readline8.2.patch. Beside that no surprises and from my side you
can go ahead.
Greetings
Frank
> --joel
> On Wed, Feb 22, 2023 at 3:29 AM Frank Kühndel <
> frank.kuehndel at embedded-brains.de> wrote:
>> Hello Joel,
>> On 2/21/23 16:25, Joel Sherrill wrote:
>>> Subject:
>>> From:
>>> Joel Sherrill<joel at rtems.org>
>>> Date:
>>> 2/21/23, 16:25
>>> To:
>>> devel at rtems.org
>>>    rtems/config/6/rtems-default.bset     |  2 +-
>>>    rtems/config/tools/rtems-gdb-13.1.cfg | 16 ++++++++++++++++
>>>    2 files changed, 17 insertions(+), 1 deletion(-)
>>>    create mode 100644 rtems/config/tools/rtems-gdb-13.1.cfg
>>> diff --git a/rtems/config/6/rtems-default.bset
>> b/rtems/config/6/rtems-default.bset
>>> index a0601aa..a76efe6 100644
>>> --- a/rtems/config/6/rtems-default.bset
>>> +++ b/rtems/config/6/rtems-default.bset
>>> @@ -12,7 +12,7 @@
>>>    %defineifnot with_rtems_dtc      devel/dtc-1.6.1-1
>>>    %defineifnot with_rtems_expat    devel/expat-2.4.8-1
>>>    %defineifnot with_rtems_gmp      devel/gmp-6.2.1
>>> -%defineifnot with_rtems_gdb      tools/rtems-gdb-12.1
>>> +%defineifnot with_rtems_gdb      tools/rtems-gdb-13.1
>>>    %defineifnot with_rtems_binutils tools/rtems-binutils-2.38
>>>    %defineifnot with_rtems_gcc      tools/rtems-gcc-12-newlib-head
>>>    %defineifnot with_rtems_tools    tools/rtems-tools-6
>>> diff --git a/rtems/config/tools/rtems-gdb-13.1.cfg
>> b/rtems/config/tools/rtems-gdb-13.1.cfg
>>> new file mode 100644
>>> index 0000000..4a6a1c7
>>> --- /dev/null
>>> +++ b/rtems/config/tools/rtems-gdb-13.1.cfg
>>> @@ -0,0 +1,16 @@
>>> +# GDB 12.1
>> Is 12.1 correct? It looks like a copy-paste error.
>> Greetings
>> Frank
>>> +%include %{_configdir}/checks.cfg
>>> +%include %{_configdir}/base.cfg
>>> +%define gdb_version 13.1
>>> +%define gdb_src_ext xz
>>> +%hash sha512 gdb-%{gdb_version}.tar.xz \
>>   5lBU/7wDV+7tSxfh7cXvRapzyd3zsSEGUePYWVduJ8HSeyZoAP4mMo7aWIV0VczYYy9AAM/F9j+QhUCWKQGHyg==
>>> +#%patch add gdb --rsb-file=gdb-readline8.2.patchhttps://
>> sourceware.org/git/?p=binutils-gdb.git;a=commitdiff_plain;h=1add37b567a7dee39d99f37b37802034c3fce9c4
>>> +#%hash sha512 gdb-readline8.2.patch
>> E/nGalfBBfn0rl/pi1SGIuKD11x0qREZBp3ajaFbl/nGMZUIm31M/1z0FsG76K7IjvE5pPsl2JqESt+LBN9lZA==
>>> +%include %{_configdir}/gdb-common-1.cfg
>>> -- 2.24.4 _______________________________________________ devel mailing
>>> listdevel at rtems.org  http://lists.rtems.org/mailman/listinfo/devel
>> embedded brains GmbH
>> Herr Frank KÜHNDEL
>> Dornierstr. 4
>> 82178 Puchheim
>> Germany
>> email:frank.kuehndel at embedded-brains.de
>> phone:  +49-89-18 94 741 - 23
>> mobile: +49-176-15 22 06 - 11
>> fax:    +49-89-18 94 741 - 08
>> Registergericht: Amtsgericht München
>> Registernummer: HRB 157899
>> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
>> Unsere Datenschutzerklärung finden Sie hier:
>> https://embedded-brains.de/datenschutzerklaerung/
>> devel mailing list
>> devel at rtems.org
Herr Frank KÜHNDEL
Dornierstr. 4
82178 Puchheim
Germany
email: frank.kuehndel at embedded-brains.de
