Jetson Nano BSP
Christian MAUDERER
christian.mauderer at embedded-brains.de
Thu Feb 23 12:58:57 UTC 2023
Hello,
On 2023-02-23 06:15, Joel Sherrill wrote:
> On Wed, Feb 22, 2023, 9:26 PM Prakhar Agrawal
> <prakhar.agrawal001 at gmail.com <mailto:prakhar.agrawal001 at gmail.com>> wrote:
> Hello,
> Does the current RTEMS version support the Jetson nano board, if
> not, do you think It will be a good project for gsoc2023? something
> like porting RTEMS to Jetson nano or jetson AGX orin maybe?
> I'm torn whether this is a good project or not. It is quite ambitious
> but it appears that a fair amount of the boards horsepower is tied to
> binary blobs which likely won't work with RTEMS.
> One challenge is that much of the support will be GPL licensed which is
> unacceptable for RTEMS.
> That said, it may be feasible since freebsd appears to support it now. I
> have no idea what devices work under freebsd. But if you can boot
> freebsd on it and see what works, that would be great information.
> https://cgit.freebsd.org/src/commit/?id=e903478919602c90fdc202a8628b89eb7c3bc104 <https://cgit.freebsd.org/src/commit/?id=e903478919602c90fdc202a8628b89eb7c3bc104>
> The other side of this is how useful this will be either for RTEMS
> users. What would a hobbyist use it for? A production team?
> Is the board too old to be worth the effort for the limited audience?
The Jetson seems to be a big familiy. The Nano is from 2019 and has some
chip that is most likely based on a chip from 2015? The Orin Nano is
from September 2022 with some CPU that I didn't find on a quick search.
Otherwise, I fully agree with what Joel said: Do we have some audience
for it? They are not really cheap so hobby use is unlikely.
I haven't found any source where I could buy small numbers of blank
chips. In my experience, that often means that the manufacturer targets
products where they sell big numbers of chips (at least 6 digit
numbers). For these it's usually cheaper if the manufacturer just
assigns a field application engineer to you instead of writing good
documentation. If the Jetson falls into that category, it's not an easy
project.
> Honestly I'd rather see a new BSP for a decent RISC-V board.
Decent and not too expensive RISC-V would be interesting, but I haven't
found too much of these yet. Only expensive stuff like the Renesas
RZ/Five evaluation board or ones that are not yet easily available like
the Pine Ox64 that I mentioned in other GSoC discussions already. If you
find a nice cheap RISC-V board, it would be a great project. Other
commonly available and well documented non-RISC-V boards or simulator
targets can be interesting projects too.
Best regards
Christian
> Looking forward to your response.
> I'm also curious to hear what others think.
> --joel
> Best Regards
> Prakhar
> devel mailing list
> devel at rtems.org <mailto:devel at rtems.org>
> <http://lists.rtems.org/mailman/listinfo/devel>
> devel mailing list
> devel at rtems.org
embedded brains GmbH
Herr Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 18
mobile: +49-176-152 206 08
Registernummer: HRB 157899
