[PATCH 1/3] build: Format build items
Kinsey Moore
wkm042 at oarcorp.com
Thu Jan 12 21:06:05 UTC 2023
On 1/12/2023 10:38 AM, Sebastian Huber wrote:
> On 12.01.23 16:52, Kinsey Moore wrote:
>> Annotation of expected test states with a description could get quite
>> repetitive, but I suppose that's better than losing the information.
>> I'm fine with this going in for now with a ticket to address this
>> issue and we can pull the annotations back in when the ticket is
>> dealt with.
> It could look like this:
> SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> actions:
> - set-test-state:
> - reason: |
> expected to fail, don't compile these
> state: exclude
> tests:
> - minimum
> - reason: |
> tests that are passing intermittently
> state: indeterminate
> tests:
> - psx12
> - psxtimes01
> - rtmonuse
> - rtmonusxtimes01
> - sp04
> - sp20
> - sp68
> - sp69
> - spcpucounter01
> - spedfsched02
> - spedfsched04
> - sprmsched01
> - sptimecounter02
> - sptimecounter04
> - ttest02
> - reason: |
> tests that pass nominally, but fail under Qemu when the host is
> under
> heavy load
> tests:
> - spintrcritical03
> - spintrcritical04
> - spintrcritical05
> build-type: option
> copyrights:
> - Copyright (C) 2020 On-Line Applications Research (OAR)
> default: []
> description: ''
> enabled-by: true
> links: []
> type: build
That seems like a reasonable format for test state expectations.
Kinsey
