[docs] eng: Use a recommendation for requirement texts
Fri Jan 20 22:55:56 UTC 2023
I understand this change. I wonder if there are some terms that you
definitely want to avoid though?
Do you have tooling to warn on the use of these terms in requirements?
If not, that could be something easy for a student to put together as
a beginner/janitor task.
On Tue, Jan 17, 2023 at 8:38 AM Sebastian Huber
> Update #3715.
>  eng/req/items.rst | 126 +++++++++++++++++++++++-----------------------
>  1 file changed, 63 insertions(+), 63 deletions(-)
> diff --git a/eng/req/items.rst b/eng/req/items.rst
> index 95531a8..19e8726 100644
> --- a/eng/req/items.rst
> +++ b/eng/req/items.rst
> @@ -4597,130 +4597,130 @@ of links.
>  Requirement Text
> -The value shall be a string. It shall state a requirement or constraint. The
> -value shall not contain an element of
> +The value shall be a string. It shall state a requirement or constraint.  The
> +text should not use one of the following words or phrases:
> -* "``acceptable``",
> +* acceptable
> -* "``adequate``",
> +* adequate
> -* "``almost always``",
> +* almost always
> -* "``and/or``",
> +* and/or
> -* "``appropriate``",
> +* appropriate
> -* "``approximately``",
> +* approximately
> -* "``as far as possible``",
> +* as far as possible
> -* "``as much as practicable``",
> +* as much as practicable
> -* "``best``",
> +* best
> -* "``best possible``",
> +* best possible
> -* "``easy``",
> +* easy
> -* "``efficient``",
> +* efficient
> -* "``e.g.``",
> +* e.g.
> -* "``enable``",
> +* enable
> -* "``enough``",
> +* enough
> -* "``etc.``",
> +* etc.
> -* "``few``",
> +* few
> -* "``first rate``",
> +* first rate
> -* "``flexible``",
> +* flexible
> -* "``generally``",
> +* generally
> -* "``goal``",
> +* goal
> -* "``graceful``",
> +* graceful
> -* "``great``",
> +* great
> -* "``greatest``",
> +* greatest
> -* "``ideally``",
> +* ideally
> -* "``i.e.``",
> +* i.e.
> -* "``if possible``",
> +* if possible
> -* "``in most cases``",
> +* in most cases
> -* "``large``",
> +* large
> -* "``many``",
> +* many
> -* "``maximize``",
> +* maximize
> -* "``minimize``",
> +* minimize
> -* "``most``",
> +* most
> -* "``multiple``",
> +* multiple
> -* "``necessary``",
> +* necessary
> -* "``numerous``",
> +* numerous
> -* "``optimize``",
> +* optimize
> -* "``ought to``",
> +* ought to
> -* "``probably``",
> +* probably
> -* "``quick``",
> +* quick
> -* "``rapid``",
> +* rapid
> -* "``reasonably``",
> +* reasonably
> -* "``relevant``",
> +* relevant
> -* "``robust``",
> +* robust
> -* "``satisfactory``",
> +* satisfactory
> -* "``several``",
> +* several
> -* "``shall be included but not limited to``",
> +* shall be included but not limited to
> -* "``simple``",
> +* simple
> -* "``small``",
> +* small
> -* "``some``",
> +* some
> -* "``state of the art``",
> +* state of the art
> -* "``sufficient``",
> +* sufficient
> -* "``suitable``",
> +* suitable
> -* "``support``",
> +* support
> -* "``systematically``",
> +* systematically
> -* "``transparent``",
> +* transparent
> -* "``typical``",
> +* typical
> -* "``user friendly``",
> +* user friendly
> -* "``usually``",
> +* usually
> -* "``versatile``", and
> +* versatile
> -* "``when necessary``".
> +* when necessary
>  This type is used by the following types:
> 2.35.3
> devel mailing list
> devel at rtems.org
