RTEMS-libbsd freebsd-org submodule would require update in order to import genet drivers. Suggestions?
Noor Aman nooraman5718 at gmail.com
Sun Jun 4 15:44:46 UTC 2023
Ping, I still require some assistance.
Else I'll go by with Kinsey's suggestion as follows:
> If it turns out we can't trivially bring things up to current, you may
> need to import the current updated driver from freebsd master into rtemsbsd
> and maintain it out of tree.
Thanks
On Thu, 1 Jun 2023 at 23:46, Noor Aman <nooraman5718 at gmail.com> wrote:
> Hello,
> Currently freebsd-org submodule is currently checked out at hash-ID
> 5d85e12 dated September 24, 2019 in master rtems-libbsd branch. In order to
> import genet drivers, I need to at least get commit from april 2020.
> Specifically this one https://reviews.freebsd.org/D24436
> In terms of freebsd release numbers, I need freebsd 13.x candidate in
> order to import genet drivers. There are no drivers for it in freebsd 12.x.
> From what I have read in the documentation, the working directory needs to
> be clean in order to start importing process, but i'm unable to do so when
> switching to main or master branch. What should I do? Any suggestions?
> Thank you,
Mohd Noor Aman
Tinkering with Hardware
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230604/73f10429/attachment.htm>
