RTEMS-libbsd freebsd-org submodule would require update in order to import genet drivers. Suggestions?
Alan Cudmore alan.cudmore at gmail.com
Sun Jun 4 16:51:02 UTC 2023
Hi Noor,
If you have not done so already, would it be worth trying to build and
initialize the current libbsd with a loopback driver?
Are there other devices on the RPI4 such as the SD card or USB that may be
usable in the current libbsd on the Pi 4?
I know it will not get you the ethernet driver you need, but having an
environment that runs on the board might be a step in the right direction.
How hard do you think it would be to backport the ethernet driver to the
current rtems-libbsd release?
Alan
On Sun, Jun 4, 2023 at 11:45 AM Noor Aman <nooraman5718 at gmail.com> wrote:
> Ping, I still require some assistance.
> Else I'll go by with Kinsey's suggestion as follows:
>> If it turns out we can't trivially bring things up to current, you may
>> need to import the current updated driver from freebsd master into rtemsbsd
>> and maintain it out of tree.
> Thanks
> On Thu, 1 Jun 2023 at 23:46, Noor Aman <nooraman5718 at gmail.com> wrote:
>> Hello,
>> Currently freebsd-org submodule is currently checked out at hash-ID
>> 5d85e12 dated September 24, 2019 in master rtems-libbsd branch. In order to
>> import genet drivers, I need to at least get commit from april 2020.
>> Specifically this one https://reviews.freebsd.org/D24436
>> In terms of freebsd release numbers, I need freebsd 13.x candidate in
>> order to import genet drivers. There are no drivers for it in freebsd 12.x.
>> From what I have read in the documentation, the working directory needs
>> to be clean in order to start importing process, but i'm unable to do so
>> when switching to main or master branch. What should I do? Any suggestions?
>> Thank you,
> Mohd Noor Aman
> Tinkering with Hardware
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230604/f10f2cb0/attachment.htm>
