bsps/xilinx-zynqmp : Add BSP for RPU
mbenson at windhoverlabs.com
Wed Jun 14 17:07:27 UTC 2023
This is great. I will carve out time to check this out on the ZU3EG and provide feedback if needed. Good job.
Sent from my iPhone
> On Jun 14, 2023, at 08:49, Joel Sherrill <joel at rtems.org> wrote:
> Thanks for submitting this. It has been on the wish list for a while.
> My first comment is that information needs to be added to the Users Guide on
> this BSP. Guidance on capabilities, use, and debug is always appreciated by the
> next user. Remember that often this is where search engines and other humans
> find out if something is supported.
> Comments inline. Hoping others who know this hardware better do a more
> technical review.
>> On Wed, Jun 14, 2023 at 3:08 AM Philip Kirkpatrick <p.kirkpatrick at reflexaerospace.com> wrote:
>> This patch adds support for running RTEMS on the RPU (cortex R5) cores of the ZynqMP. This is only a basic BSP and does not yet support the following:
>> - SMP
>> - Cache
>> - MPU
>> Also, everything except for the startup and exception vectors runs out of DRAM, which is slow without cache. At some point in the future, I plan to move some of the fast memory sections to ATCM and BTCM and enable cache.
>> Lastly, credit to Stanislav (s.pankevich at gmail.com, also on this mailing list), for internal reviews and feedback.
>> The steps done to implement this BSP are as follows:
>> - to xilinx_zynqmp_ultra96 bsp (spec/build/bsps/arm/xilinx-zynqmp/*)
>> - Added optprocunitapu.yml to pass C define ZYNQMP_PROC_UNIT_APU
>> - Copied xilinx_zynqmp_ultra96 bsp to xilinx_zynqmp_mercuryxu5_rpu in spec/build/bsps/arm/xilinx-zynqmp-rpu/*
>> - In new BSP
>> - changed optprocunitapu.yml to optprocunitrpu.yml to pass C define ZYNQMP_PROC_UNIT_RPU
>> - Removed all things regarding MMU, and SMP
>> - Changed source: bsps/arm/shared/cache/cache-cp15.c to bsps/shared/cache/nocache.c
>> - Removed all other references to cache
>> - Changed abi flags
>> - Updated the linkcmds to remove MMU and cache sections.
>> - Updated optint0len, optint0ori, optint1len, and optint1ori to target ATCM and BTCM.
>> - Updated linkcmds to place START and VECTOR regions in ATCM
>> - In BSP C sources
>> - Used ZYNQMP_PROC_UNIT_APU and ZYNQMP_PROC_UNIT_RPU to enable/disable MPU, SMP, and cache.
>> - Used PROC_UNIT flags to control GIC address.
>> - Added hook0 code for RPU code to make sure SCTLR[M, I, A, C, V] are cleared
>> - Created a timer driver for the Triple Timer Counter (TTC) module since the RPU doesn't have an ARM generic timer
>> diff --git a/bsps/arm/xilinx-zynqmp/clock/clock-ttc.c b/bsps/arm/xilinx-zynqmp/clock/clock-ttc.c
>> new file mode 100644
>> index 0000000000..dd0bc3a3c9
>> --- /dev/null
>> +++ b/bsps/arm/xilinx-zynqmp/clock/clock-ttc.c
>> @@ -0,0 +1,219 @@
>> + * @file
>> + * @ingroup RTEMSBSPsARMZynqMP
>> + * @brief Triple Timer Counter clock functions definitions.
>> + * SPDX-License-Identifier: BSD-2-Clause
>> + * Copyright (C) 2023 Reflex Aerospace GmbH
>> + * Written by Philip Kirkpatrick <p.kirkpatrick at reflexaerospace.com>
>> + * Redistribution and use in source and binary forms, with or without
>> + * modification, are permitted provided that the following conditions
>> + * are met:
>> + * 1. Redistributions of source code must retain the above copyright
>> + * notice, this list of conditions and the following disclaimer.
>> + * 2. Redistributions in binary form must reproduce the above copyright
>> + * notice, this list of conditions and the following disclaimer in the
>> + * documentation and/or other materials provided with the distribution.
>> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
>> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
>> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
>> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
>> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
>> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
>> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
>> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
>> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
>> + * POSSIBILITY OF SUCH DAMAGE.
>> +#include <stdlib.h>
>> +#include <rtems.h>
>> +#include <bsp.h>
>> +#include <bsp/irq.h>
>> +#include <bsp/zynqmp.h>
>> +#include <bsp/xttcps_hw.h>
>> +#include <rtems/timecounter.h>
>> +static struct timecounter zynqmp_ttc_tc;
>> +#define TTC_REFERENCE_CLOCK 100000000
>> +/* This is defined in dev/clock/clockimpl.h */
>> +void Clock_isr(rtems_irq_hdl_param arg);
>> +static uint32_t irq_match_interval;
>> +static uint32_t zynqmp_ttc_get_timecount(struct timecounter *tc)
>> + uint32_t time;
>> + time = XTtcPs_ReadReg(ZYNQMP_TTC0, XTTCPS_COUNT_VALUE_OFFSET);
>> + return time;
>> + * @brief Initialize the HW peripheral for clock driver
>> + * Clock driver is implemented by RTI module
>> + * @retval Void
>> +static void zynqmp_ttc_clock_driver_support_initialize_hardware( void )
>> + uint32_t microsec_per_tick;
>> + uint16_t clock_ratio;
>> + uint8_t index;
>> + uint32_t frequency;
>> + uint32_t prescaler;
>> + uint32_t tmp_reg_val;
>> + microsec_per_tick = rtems_configuration_get_microseconds_per_tick();
>> + /* Check the TTC is OFF before reconfiguring */
>> + XTtcPs_WriteReg(ZYNQMP_TTC0, XTTCPS_CNT_CNTRL_OFFSET, XTTCPS_CNT_CNTRL_DIS_MASK |
>> + XTTCPS_CNT_CNTRL_EN_WAVE_MASK); // Don't enable waveform output (active low)
>> + /* Prescaler value is 2^(N + 1) */
>> + /* Divide down the clock as much as possible while still retaining a */
>> + /* frequency that is an integer multiple of 1MHz. This maximizes time to */
>> + /* overflow while minimizing rounding errors in 1us periods */
>> + clock_ratio = TTC_REFERENCE_CLOCK / 1000000;
>> + /* Search for the highest set bit. This is effectively min(log2(ratio))*/
>> + for(index = sizeof(clock_ratio) * 8 - 1; index > 0; index--)
>> + if((clock_ratio >> (index)) & 0x01)
>> + break;
> The RTEMS style would have this more like:
> for (...) {
> if (...) {
> break;
> There is a nearly finished format configuration for clang-format which might
> help. Gedare is trying to finish that up.
>> + if(index == 0 && (clock_ratio & 0x01 == 0))
>> + // No prescaler
>> + frequency = TTC_REFERENCE_CLOCK;
>> + XTtcPs_WriteReg(ZYNQMP_TTC0, XTTCPS_CLK_CNTRL_OFFSET, 0);
>> + else
>> + prescaler = index - 1;
>> + frequency = TTC_REFERENCE_CLOCK / (1 << (prescaler + 1));
>> + prescaler << XTTCPS_CLK_CNTRL_PS_VAL_SHIFT |
>> + XTTCPS_CLK_CNTRL_PS_EN_MASK);
>> + /* Max out the counter interval */
>> + tmp_reg_val = XTTCPS_INTERVAL_VAL_MASK;
>> + XTtcPs_WriteReg(ZYNQMP_TTC0, XTTCPS_INTERVAL_VAL_OFFSET, tmp_reg_val);
>> + /* Setup match register to generate tick IRQ */
>> + irq_match_interval = (uint32_t) ((frequency * microsec_per_tick) / 1000000);
>> + XTtcPs_WriteReg(ZYNQMP_TTC0, XTTCPS_MATCH_0_OFFSET, irq_match_interval);
>> + /* Clear interupts (clear on read) */
>> + XTtcPs_ReadReg(ZYNQMP_TTC0, XTTCPS_ISR_OFFSET);
>> + /* Enable interupt for match register */
>> + XTtcPs_WriteReg(ZYNQMP_TTC0, XTTCPS_IER_OFFSET, XTTCPS_IXR_MATCH_0_MASK);
>> + /* Configure, reset, and enable counter */
>> + XTTCPS_CNT_CNTRL_EN_WAVE_MASK | /* Don't enable waveform output (active low) */
>> + XTTCPS_CNT_CNTRL_RST_MASK | /* Reset count and start counter */
>> + XTTCPS_CNT_CNTRL_MATCH_MASK /* Enable match mode */
>> + /* Increment mode */
>> + /* Overflow mode */
>> + /* Not disabled */
>> + /* set timecounter */
>> + zynqmp_ttc_tc.tc_get_timecount = zynqmp_ttc_get_timecount;
>> + zynqmp_ttc_tc.tc_counter_mask = XTTCPS_COUNT_VALUE_MASK;
>> + zynqmp_ttc_tc.tc_frequency = frequency;
>> + zynqmp_ttc_tc.tc_quality = RTEMS_TIMECOUNTER_QUALITY_CLOCK_DRIVER;
>> + rtems_timecounter_install(&zynqmp_ttc_tc);
>> + * @brief Clears interrupt source
>> + * @retval Void
>> +static uint32_t tick_miss = 0;
>> +static void zynqmp_ttc_clock_driver_support_at_tick( void )
>> + uint32_t irq_flags;
>> + uint32_t cval;
>> + uint32_t now;
>> + uint32_t delta;
>> + /* Get and clear interupts (clear on read) */
>> + irq_flags = XTtcPs_ReadReg(ZYNQMP_TTC0, XTTCPS_ISR_OFFSET);
>> + if(irq_flags & XTTCPS_IXR_MATCH_0_MASK)
>> + /* Update match */
>> + cval = XTtcPs_ReadReg(ZYNQMP_TTC0, XTTCPS_MATCH_0_OFFSET);
>> + /* Check that the match for the next tick is in the future */
>> + /* If no, then set the match for one irq interval from now */
>> + /* This will have the effect that your timebase will slip but */
>> + /* won't hang waiting for the counter to wrap around. */
>> + /* If this happens durring normal opteration, there is a problem */
>> + /* causing this interrupt to not be serviced quickly enough */
>> + /* If this happens during debugging, that is normal and expected */
>> + /* becaue the TTC does NOT pause when the CPU is halted on a breakpoint */
> Turn this into a multiline comment like this:
>> + now = XTtcPs_ReadReg(ZYNQMP_TTC0, XTTCPS_COUNT_VALUE_OFFSET);
>> + delta = now - cval;
>> + if(delta > irq_match_interval)
>> + cval = now;
>> + tick_miss++;
>> + cval += irq_match_interval;
>> + XTtcPs_WriteReg(ZYNQMP_TTC0, XTTCPS_MATCH_0_OFFSET, cval);
>> + /* Else, something is set up wrong, only match should be enabled */
>> + * @brief registers RTI interrupt handler
>> + * @param[in] Clock_isr new ISR handler
>> + * @param[in] Old_ticker old ISR handler (unused and type broken)
>> + * @retval Void
>> +static void zynqmp_ttc_clock_driver_support_install_isr(
>> + rtems_isr_entry Clock_isr
>> + rtems_status_code sc = RTEMS_SUCCESSFUL;
>> + sc = rtems_interrupt_handler_install(
>> + ZYNQMP_IRQ_TTC_0_0,
>> + "Clock",
>> + RTEMS_INTERRUPT_UNIQUE,
>> + (rtems_interrupt_handler) Clock_isr,
>> + NULL
>> + if ( sc != RTEMS_SUCCESSFUL ) {
>> + rtems_fatal_error_occurred(0xdeadbeef);
>> +#define Clock_driver_support_at_tick \
>> + zynqmp_ttc_clock_driver_support_at_tick
>> +#define Clock_driver_support_initialize_hardware \
>> + zynqmp_ttc_clock_driver_support_initialize_hardware
>> +#define Clock_driver_support_install_isr(Clock_isr) \
>> + zynqmp_ttc_clock_driver_support_install_isr( Clock_isr )
>> +#include "../../../shared/dev/clock/clockimpl.h"
>> diff --git a/bsps/arm/xilinx-zynqmp/config/xilinx_zynqmp_rpu.inc b/bsps/arm/xilinx-zynqmp/config/xilinx_zynqmp_rpu.inc
>> index 0000000000..f97f4d5018
>> --- /dev/null
>> +++ b/bsps/arm/xilinx-zynqmp/config/xilinx_zynqmp_rpu.inc
>> @@ -0,0 +1,10 @@
>> +include $(RTEMS_ROOT)/make/custom/default.cfg
>> +RTEMS_CPU = arm
>> +CPU_CFLAGS = -march=armv7-r -mthumb -mfpu=vfpv3-d16 -mfloat-abi=hard
>> +CFLAGS_OPTIMIZE_V ?= -O2 -g
>> +CFLAGS_OPTIMIZE_V += -ffunction-sections -fdata-sections
>> +LDFLAGS = -Wl,--gc-sections
>> diff --git a/bsps/arm/xilinx-zynqmp/include/bsp.h b/bsps/arm/xilinx-zynqmp/include/bsp.h
>> index 9d33cf6134..d0b4b9d644 100644
>> --- a/bsps/arm/xilinx-zynqmp/include/bsp.h
>> +++ b/bsps/arm/xilinx-zynqmp/include/bsp.h
>> @@ -64,9 +64,17 @@
>> extern "C" {
>> #endif /* __cplusplus */
>> +#ifdef ZYNQMP_PROC_UNIT_APU
>> #define BSP_ARM_GIC_CPUIF_BASE 0xf9020000
>> #define BSP_ARM_GIC_DIST_BASE 0xf9010000
>> +#endif
>> +#ifdef ZYNQMP_PROC_UNIT_RPU
>> +#define BSP_ARM_GIC_CPUIF_BASE 0x00F9001000
>> +#define BSP_ARM_GIC_DIST_BASE 0xF9000000
>> +#endif
>> #define BSP_ARM_A9MPCORE_SCU_BASE 0
>> diff --git a/bsps/arm/xilinx-zynqmp/include/bsp/irq.h b/bsps/arm/xilinx-zynqmp/include/bsp/irq.h
>> index 9aae8168db..a8271bebb5 100644
>> --- a/bsps/arm/xilinx-zynqmp/include/bsp/irq.h
>> +++ b/bsps/arm/xilinx-zynqmp/include/bsp/irq.h
>> @@ -56,17 +56,32 @@ extern "C" {
>> * @brief Interrupt Support
>> /* PPIs */
>> #define ZYNQMP_IRQ_HYP_TIMER 26
>> #define ZYNQMP_IRQ_VIRT_TIMER 27
>> #define ZYNQMP_IRQ_S_PHYS_TIMER 29
>> #define ZYNQMP_IRQ_NS_PHYS_TIMER 30
>> +#endif
>> /* SPIs */
>> #define ZYNQMP_IRQ_UART_0 53
>> #define ZYNQMP_IRQ_UART_1 54
>> +#define ZYNQMP_IRQ_TTC_0_0 68
>> +#define ZYNQMP_IRQ_TTC_0_1 69
>> +#define ZYNQMP_IRQ_TTC_0_2 70
>> +#define ZYNQMP_IRQ_TTC_1_0 71
>> +#define ZYNQMP_IRQ_TTC_1_1 72
>> +#define ZYNQMP_IRQ_TTC_1_2 73
>> +#define ZYNQMP_IRQ_TTC_2_0 74
>> +#define ZYNQMP_IRQ_TTC_2_1 75
>> +#define ZYNQMP_IRQ_TTC_2_2 76
>> +#define ZYNQMP_IRQ_TTC_3_0 77
>> +#define ZYNQMP_IRQ_TTC_3_1 78
>> +#define ZYNQMP_IRQ_TTC_3_2 79
>> #define BSP_INTERRUPT_VECTOR_COUNT 188
>> diff --git a/bsps/arm/xilinx-zynqmp/include/bsp/xttcps_hw.h b/bsps/arm/xilinx-zynqmp/include/bsp/xttcps_hw.h
>> index 0000000000..ba0d559b07
>> --- /dev/null
>> +++ b/bsps/arm/xilinx-zynqmp/include/bsp/xttcps_hw.h
>> @@ -0,0 +1,223 @@
>> +* Copyright (C) 2010 - 2021 Xilinx, Inc. All rights reserved.
>> +* SPDX-License-Identifier: MIT
> Someone else should comment on whether this Xilinx file should be in
> a location where it is shareable by other BSPs.
> Is this file unmodified from the Xilinx provided version? Changes for
> RTEMS should be inside conditional like "#ifdef __rtems__" or
> "#ifndef __rtems__"
>> +* @file xttcps_hw.h
>> +* @addtogroup ttcps_v3_14
>> +* This file defines the hardware interface to one of the three timer counters
>> +* in the Ps block.
>> +* <pre>
>> +* MODIFICATION HISTORY:
>> +* Ver Who Date Changes
>> +* 1.00a drg/jz 01/21/10 First release
>> +* 3.00 kvn 02/13/15 Modified code for MISRA-C:2012 compliance.
>> +* 3.5 srm 10/06/17 Updated XTTCPS_COUNT_VALUE_MASK,
>> +* XTTCPS_INTERVAL_VAL_MASK, XTTCPS_MATCH_MASK macros to
>> +* mask 16 bit values for zynq and 32 bit values for
>> +* zynq ultrascale+mpsoc "
>> +* </pre>
>> +#ifndef XTTCPS_HW_H /* prevent circular inclusions */
>> +#define XTTCPS_HW_H /* by using protection macros */
>> +#ifdef __cplusplus
>> +extern "C" {
>> +#endif
>> +/***************************** Include Files *********************************/
>> +#ifndef __rtems__
>> +#include "xil_types.h"
>> +#include "xil_assert.h"
>> +#include "xil_io.h"
>> +#else
>> +static inline u32 Xil_In32(UINTPTR Addr)
>> + return *(volatile u32 *) Addr;
>> +static inline void Xil_Out32(UINTPTR Addr, u32 Value)
>> + volatile u32 *LocalAddr = (volatile u32 *)Addr;
>> + *LocalAddr = Value;
>> +#endif /* __rtems__ */
>> +/************************** Constant Definitions *****************************/
>> + * Flag for a9 processor
>> +#if 0
>> + #if !defined (ARMR5) && !defined (__aarch64__) && !defined (ARMA53_32)
>> + #define ARMA9
>> + #endif
>> +#endif
>> +/** @name Register Map
>> + * Register offsets from the base address of the device.
>> +#define XTTCPS_CLK_CNTRL_OFFSET 0x00000000U /**< Clock Control Register */
>> +#define XTTCPS_CNT_CNTRL_OFFSET 0x0000000CU /**< Counter Control Register*/
>> +#define XTTCPS_COUNT_VALUE_OFFSET 0x00000018U /**< Current Counter Value */
>> +#define XTTCPS_INTERVAL_VAL_OFFSET 0x00000024U /**< Interval Count Value */
>> +#define XTTCPS_MATCH_0_OFFSET 0x00000030U /**< Match 1 value */
>> +#define XTTCPS_MATCH_1_OFFSET 0x0000003CU /**< Match 2 value */
>> +#define XTTCPS_MATCH_2_OFFSET 0x00000048U /**< Match 3 value */
>> +#define XTTCPS_ISR_OFFSET 0x00000054U /**< Interrupt Status Register */
>> +#define XTTCPS_IER_OFFSET 0x00000060U /**< Interrupt Enable Register */
>> +/** @name Clock Control Register
>> + * Clock Control Register definitions
>> +#define XTTCPS_CLK_CNTRL_PS_EN_MASK 0x00000001U /**< Prescale enable */
>> +#define XTTCPS_CLK_CNTRL_PS_VAL_MASK 0x0000001EU /**< Prescale value */
>> +#define XTTCPS_CLK_CNTRL_PS_VAL_SHIFT 1U /**< Prescale shift */
>> +#define XTTCPS_CLK_CNTRL_PS_DISABLE 16U /**< Prescale disable */
>> +#define XTTCPS_CLK_CNTRL_SRC_MASK 0x00000020U /**< Clock source */
>> +#define XTTCPS_CLK_CNTRL_EXT_EDGE_MASK 0x00000040U /**< External Clock edge */
>> +/** @name Counter Control Register
>> + * Counter Control Register definitions
>> +#define XTTCPS_CNT_CNTRL_DIS_MASK 0x00000001U /**< Disable the counter */
>> +#define XTTCPS_CNT_CNTRL_INT_MASK 0x00000002U /**< Interval mode */
>> +#define XTTCPS_CNT_CNTRL_DECR_MASK 0x00000004U /**< Decrement mode */
>> +#define XTTCPS_CNT_CNTRL_MATCH_MASK 0x00000008U /**< Match mode */
>> +#define XTTCPS_CNT_CNTRL_RST_MASK 0x00000010U /**< Reset counter */
>> +#define XTTCPS_CNT_CNTRL_EN_WAVE_MASK 0x00000020U /**< Enable waveform */
>> +#define XTTCPS_CNT_CNTRL_POL_WAVE_MASK 0x00000040U /**< Waveform polarity */
>> +#define XTTCPS_CNT_CNTRL_RESET_VALUE 0x00000021U /**< Reset value */
>> +/** @name Current Counter Value Register
>> + * Current Counter Value Register definitions
>> +#if defined(ARMA9)
>> +#define XTTCPS_COUNT_VALUE_MASK 0x0000FFFFU /**< 16-bit counter value */
>> +#else
>> +#define XTTCPS_COUNT_VALUE_MASK 0xFFFFFFFFU /**< 32-bit counter value */
>> +#endif
>> +/** @name Interval Value Register
>> + * Interval Value Register is the maximum value the counter will count up or
>> + * down to.
>> +#if defined(ARMA9)
>> +#define XTTCPS_INTERVAL_VAL_MASK (u32)(0x0000FFFF) /**< 16-bit Interval value*/
>> +#else
>> +#define XTTCPS_INTERVAL_VAL_MASK (u32)(0xFFFFFFFF) /**< 32-bit Interval value*/
>> +#endif
>> +/** @name Match Registers
>> + * Definitions for Match registers, each timer counter has three match
>> + * registers.
>> +#if defined(ARMA9)
>> +#define XTTCPS_MATCH_MASK 0x0000FFFFU /**< 16-bit Match value */
>> +#else
>> +#define XTTCPS_MATCH_MASK 0xFFFFFFFFU /**< 32-bit Match value */
>> +#endif
>> +#define XTTCPS_NUM_MATCH_REG 3U /**< Num of Match reg */
>> +/** @name Interrupt Registers
>> + * Following register bit mask is for all interrupt registers.
>> +#define XTTCPS_IXR_INTERVAL_MASK 0x00000001U /**< Interval Interrupt */
>> +#define XTTCPS_IXR_MATCH_0_MASK 0x00000002U /**< Match 1 Interrupt */
>> +#define XTTCPS_IXR_MATCH_1_MASK 0x00000004U /**< Match 2 Interrupt */
>> +#define XTTCPS_IXR_MATCH_2_MASK 0x00000008U /**< Match 3 Interrupt */
>> +#define XTTCPS_IXR_CNT_OVR_MASK 0x00000010U /**< Counter Overflow */
>> +#define XTTCPS_IXR_ALL_MASK 0x0000001FU /**< All valid Interrupts */
>> +/***************** Macros (Inline Functions) Definitions *********************/
>> +* Read the given Timer Counter register.
>> +* @param BaseAddress is the base address of the timer counter device.
>> +* @param RegOffset is the register offset to be read
>> +* @return The 32-bit value of the register
>> +* @note C-style signature:
>> +* u32 XTtcPs_ReadReg(u32 BaseAddress, u32 RegOffset)
>> +#define XTtcPs_ReadReg(BaseAddress, RegOffset) \
>> + (Xil_In32((BaseAddress) + (u32)(RegOffset)))
>> +* Write the given Timer Counter register.
>> +* @param RegOffset is the register offset to be written
>> +* @param Data is the 32-bit value to write to the register
>> +* @return None.
>> +* void XTtcPs_WriteReg(XTtcPs BaseAddress, u32 RegOffset,
>> +* u32 Data)
>> +#define XTtcPs_WriteReg(BaseAddress, RegOffset, Data) \
>> + (Xil_Out32((BaseAddress) + (u32)(RegOffset), (u32)(Data)))
>> +* Calculate a match register offset using the Match Register index.
>> +* @param MatchIndex is the 0-2 value of the match register
>> +* @return MATCH_N_OFFSET.
>> +* u32 XTtcPs_Match_N_Offset(u8 MatchIndex)
>> +#define XTtcPs_Match_N_Offset(MatchIndex) \
>> + ((u32)XTTCPS_MATCH_0_OFFSET + ((u32)(12U) * (u32)(MatchIndex)))
>> +/************************** Function Prototypes ******************************/
>> +/************************** Variable Definitions *****************************/
>> +#ifdef __cplusplus
>> +#endif
>> +#endif /* end of protection macro */
>> diff --git a/bsps/arm/xilinx-zynqmp/include/bsp/zynqmp.h b/bsps/arm/xilinx-zynqmp/include/bsp/zynqmp.h
>> index 0000000000..7a48810490
>> --- /dev/null
>> +++ b/bsps/arm/xilinx-zynqmp/include/bsp/zynqmp.h
>> @@ -0,0 +1,92 @@
> No @file block
>> + * are met:
> Blank line needed here.
>> +#ifndef LIBBSP_ARM_ZYNQMP
>> +#define LIBBSP_ARM_ZYNQMP
>> +/* Data derived from https://docs.xilinx.com/r/en-US/ug1085-zynq-ultrascale-trm/PS-I/O-Peripherals-Registers */
>> +/* LPD IO Peripherals */
>> +#define ZYNQMP_UART0 (0xFF000000)
> I'm assuming that these constants do not need to be marked as unsigned.
>> +#define ZYNQMP_UART1 (0xFF010000)
>> +#define ZYNQMP_I2C0 (0xFF020000)
>> +#define ZYNQMP_I2C1 (0xFF030000)
>> +#define ZYNQMP_SPI0 (0xFF040000)
>> +#define ZYNQMP_SPI1 (0xFF050000)
>> +#define ZYNQMP_CAN0 (0xFF060000)
>> +#define ZYNQMP_CAN1 (0xFF070000)
>> +#define ZYNQMP_GPIO (0xFF0A0000)
>> +#define ZYNQMP_GEM0 (0xFF0B0000)
>> +#define ZYNQMP_GEM1 (0xFF0C0000)
>> +#define ZYNQMP_GEM2 (0xFF0D0000)
>> +#define ZYNQMP_GEM3 (0xFF0E0000)
>> +#define ZYNQMP_QSPI (0xFF0F0000)
>> +#define ZYNQMP_NAND (0xFF100000)
>> +#define ZYNQMP_SD0 (0xFF160000)
>> +#define ZYNQMP_SD1 (0xFF170000)
>> +#define ZYNQMP_IPI_MSG (0xFF990000)
>> +#define ZYNQMP_USB0 (0xFF9D0000)
>> +#define ZYNQMP_USB1 (0xFF9E0000)
>> +#define ZYNQMP_AMS (0xFFA50000)
>> +#define ZYNQMP_PSSYSMON (0xFFA50800)
>> +#define ZYNQMP_PLSYSMON (0xFFA50C00)
>> +#define ZYNQMP_CSU_SWDT (0xFFCB0000)
>> +/* FPD IO Peripherals */
>> +#define ZYNQMP_SATA (0xFD0C0000)
>> +#define ZYNQMP_PCIE (0xFD0E0000)
>> +#define ZYNQMP_PCIE_IN (0xFD0E0800)
>> +#define ZYNQMP_PCIE_EG (0xFD0E0C00)
>> +#define ZYNQMP_PCIE_DMA (0xFD0F0000)
>> +#define ZYNQMP_SIOU (0xFD3D0000)
>> +#define ZYNQMP_GTR (0xFD400000)
>> +#define ZYNQMP_PCIE_ATTR (0xFD480000)
>> +#define ZYNQMP_DP (0xFD4A0000)
>> +#define ZYNQMP_GPU (0xFD4B0000)
>> +#define ZYNQMP_DP_DMA (0xFD4C0000)
>> +/* LPD System Registers */
>> +#define ZYNQMP_IPI (0xFF300000)
>> +#define ZYNQMP_TTC0 (0xFF110000)
>> +#define ZYNQMP_TTC1 (0xFF120000)
>> +#define ZYNQMP_TTC2 (0xFF130000)
>> +#define ZYNQMP_TTC3 (0xFF140000)
>> +#define ZYNQMP_LPD_SWDT (0xFF150000)
>> +#define ZYNQMP_XPPU (0xFF980000)
>> +#define ZYNQMP_XPPU_SINK (0xFF9C0000)
>> +#define ZYNQMP_PL_LPD (0xFF9B0000)
>> +#define ZYNQMP_OCM (0xFFA00000)
>> +#define ZYNQMP_LPD_FPD (0xFFA10000)
>> +#define ZYNQMP_RTC (0xFFA60000)
>> +#define ZYNQMP_OCM_XMPU (0xFFA70000)
>> +#define ZYNQMP_LPD_DMA (0xFFA80000)
>> +#define ZYNQMP_CSU_DMA (0xFFC80000)
>> +#define ZYNQMP_CSU (0xFFCA0000)
>> +#define ZYNQMP_BBRAM (0xFFCD0000)
>> +#endif /* LIBBSP_ARM_ZYNQMP */
>> diff --git a/bsps/arm/xilinx-zynqmp/start/bspsmp.c b/bsps/arm/xilinx-zynqmp/start/bspsmp.c
>> index 28a4b6d54d..4129e6dd59 100644
>> --- a/bsps/arm/xilinx-zynqmp/start/bspsmp.c
>> +++ b/bsps/arm/xilinx-zynqmp/start/bspsmp.c
>> @@ -34,6 +34,7 @@
>> #include <bsp/start.h>
>> bool _CPU_SMP_Start_processor(uint32_t cpu_index)
>> @@ -55,3 +56,11 @@ bool _CPU_SMP_Start_processor(uint32_t cpu_index)
>> return _Per_CPU_State_wait_for_non_initial_state(cpu_index, 0);
>> + * SMP not currently supported on RPU
>> +#endif
>> \ No newline at end of file
> Fix this.
>> diff --git a/bsps/arm/xilinx-zynqmp/start/bspstart.c b/bsps/arm/xilinx-zynqmp/start/bspstart.c
>> index fe04ef4f8f..2825653557 100644
>> --- a/bsps/arm/xilinx-zynqmp/start/bspstart.c
>> +++ b/bsps/arm/xilinx-zynqmp/start/bspstart.c
>> @@ -38,6 +38,7 @@
>> #include <libcpu/arm-cp15.h>
>> void arm_generic_timer_get_config(uint32_t *frequency, uint32_t *irq)
>> #ifdef ARM_GENERIC_TIMER_FREQ
>> @@ -53,12 +54,15 @@ void arm_generic_timer_get_config(uint32_t *frequency, uint32_t *irq)
>> *irq = ZYNQMP_IRQ_NS_PHYS_TIMER;
>> #endif
>> +#endif
>> void bsp_start(void)
>> bsp_interrupt_initialize();
>> rtems_cache_coherent_add_area(
>> bsp_section_nocacheheap_begin,
>> (uintptr_t) bsp_section_nocacheheap_size
>> +#endif
>> diff --git a/bsps/arm/xilinx-zynqmp/start/bspstarthooks.c b/bsps/arm/xilinx-zynqmp/start/bspstarthooks.c
>> index ef76563a38..07f97fb5fd 100644
>> --- a/bsps/arm/xilinx-zynqmp/start/bspstarthooks.c
>> +++ b/bsps/arm/xilinx-zynqmp/start/bspstarthooks.c
>> @@ -35,12 +35,34 @@
>> BSP_START_TEXT_SECTION void bsp_start_hook_0(void)
>> - /* Nothing to do */
>> + #ifdef ZYNQMP_PROC_UNIT_RPU
>> + * On reset, V will be set. This points the exceptions to the FSBL's vectors. The FSBL
>> + * should clear this bit before booting RTEMS but in some debugging
>> + * configurations the bit may not be. The other bits should already be clear
>> + * on reset. Since the correct settings in these bits are critical,
>> + * make sure SCTLR[M, I, A, C, V] are cleared. Afterwards, exceptions are
>> + * handled by RTEMS.
>> + * Note 1: The APU also does these steps in start.S in _start in the #if block at line 401
>> + * Note 2: Not all Arm R cores need this (like the TMS570). So, this probably should
>> + * be in this hook and not in start.S
> Are there tabs in this? Why don't the "*" line up?
>> + __asm__ volatile(
>> + "mrc p15, 0, r0, c1, c0, 0 \n"
>> + "bic r1, r0, #0x2800 \n"
>> + "bic r1, r1, #0x7 \n"
>> + "mcr p15, 0, r1, c1, c0, 0 \n"
>> + #endif
>> BSP_START_TEXT_SECTION void bsp_start_hook_1(void)
>> bsp_start_copy_sections();
>> zynqmp_setup_mmu_and_cache();
>> +#endif
>> bsp_start_clear_bss();
>> diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/abi.yml b/spec/build/bsps/arm/xilinx-zynqmp-rpu/abi.yml
>> index 0000000000..829e9c9297
>> --- /dev/null
>> +++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/abi.yml
>> @@ -0,0 +1,21 @@
>> +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
>> +actions:
>> +- get-string: null
>> +- split: null
>> +- env-append: null
>> +build-type: option
>> +copyrights:
>> +- Copyright (C) 2023 Reflex Aerospace GmbH (https://www.reflexaerospace.com/)
>> +default:
>> +- enabled-by: true
>> + value:
>> + - -march=armv7-r
>> + - -mthumb
>> + - -mfpu=vfpv3-d16
>> + - -mfloat-abi=hard
>> +description: |
>> + ABI flags
>> +enabled-by: true
>> +links: []
>> +name: ABI_FLAGS
>> +type: build
>> diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/bspmercureyxu5.yml b/spec/build/bsps/arm/xilinx-zynqmp-rpu/bspmercureyxu5.yml
>> index 0000000000..1b8b16796a
>> --- /dev/null
>> +++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/bspmercureyxu5.yml
>> @@ -0,0 +1,94 @@
>> +arch: arm
>> +bsp: xilinx_zynqmp_mercuryxu5_rpu
>> +build-type: bsp
>> +cflags: []
>> +copyrights:
>> +cppflags: []
>> +enabled-by: true
>> +family: xilinx-zynqmp
>> +includes:
>> +- bsps/include/xil/
>> +install:
>> +- destination: ${BSP_INCLUDEDIR}
>> + source:
>> + - bsps/arm/xilinx-zynqmp/include/bsp.h
>> + - bsps/include/xil/xil_types.h
>> + - bsps/include/xil/xil_assert.h
>> + - bsps/include/xil/xil_io.h
>> +- destination: ${BSP_INCLUDEDIR}/bsp
>> + source:
>> + - bsps/arm/xilinx-zynqmp/include/bsp/irq.h
>> + - bsps/arm/xilinx-zynqmp/include/bsp/xttcps_hw.h
>> + - bsps/arm/xilinx-zynqmp/include/bsp/zynqmp.h
>> +links:
>> +- role: build-dependency
>> + uid: ../grp
>> + uid: ../start
>> + uid: abi
>> + uid: optclkfastidle
>> + uid: optclkuart
>> + uid: optconirq
>> + uid: ../../optconminor
>> + uid: optint0len
>> + uid: optint0ori
>> + uid: optint1len
>> + uid: optint1ori
>> + uid: optramlen
>> + uid: optramori
>> + uid: optresetvec
>> + uid: optprocunitrpu
>> + uid: ../../obj
>> + uid: ../../objirq
>> + uid: ../../objdevserialzynq
>> + uid: ../../objdevspizynq
>> + uid: ../../objdevspixil
>> + uid: ../../objmem
>> + uid: ../../opto0
>> + uid: linkcmds
>> + uid: ../../bspopts
>> +source:
>> +- bsps/shared/cache/nocache.c
>> +- bsps/arm/shared/cp15/arm-cp15-set-exception-handler.c
>> +- bsps/arm/shared/cp15/arm-cp15-set-ttb-entries.c
>> +- bsps/arm/shared/start/bsp-start-memcpy.S
>> +- bsps/arm/xilinx-zynqmp/console/console-config.c
>> +- bsps/arm/xilinx-zynqmp/start/bspreset.c
>> +- bsps/arm/xilinx-zynqmp/start/bspstart.c
>> +- bsps/arm/xilinx-zynqmp/start/bspstarthooks.c
>> +- bsps/arm/xilinx-zynqmp/clock/clock-ttc.c
>> +- bsps/shared/dev/btimer/btimer-cpucounter.c
>> +- bsps/shared/dev/getentropy/getentropy-cpucounter.c
>> +- bsps/shared/dev/irq/arm-gicv2.c
>> +- bsps/shared/dev/irq/arm-gicv2-zynqmp.c
>> +- bsps/shared/dev/serial/console-termios.c
>> +- bsps/shared/irq/irq-default-handler.c
>> +- bsps/shared/start/bspfatal-default.c
>> +- bsps/shared/start/gettargethash-default.c
>> +- bsps/shared/start/sbrk.c
>> +- bsps/shared/start/stackalloc.c
>> +type: build
>> diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/linkcmds.yml b/spec/build/bsps/arm/xilinx-zynqmp-rpu/linkcmds.yml
>> index 0000000000..6208dc4b12
>> --- /dev/null
>> +++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/linkcmds.yml
>> @@ -0,0 +1,41 @@
>> +build-type: config-file
>> +content: |
>> + MEMORY {
>> + RAM_INT_0 : ORIGIN = ${ZYNQMP_RAM_INT_0_ORIGIN:#010x}, LENGTH = ${ZYNQMP_RAM_INT_0_LENGTH:#010x}
>> + RAM_INT_1 : ORIGIN = ${ZYNQMP_RAM_INT_1_ORIGIN:#010x}, LENGTH = ${ZYNQMP_RAM_INT_1_LENGTH:#010x}
>> + RAM : ORIGIN = ${ZYNQMP_RAM_ORIGIN:#010x}, LENGTH = ${ZYNQMP_RAM_LENGTH:#010x} - ${ZYNQMP_RAM_ORIGIN:#010x}
>> + REGION_ALIAS ("REGION_START", RAM_INT_0);
>> + REGION_ALIAS ("REGION_VECTOR", RAM_INT_0);
>> + REGION_ALIAS ("REGION_TEXT", RAM);
>> + REGION_ALIAS ("REGION_TEXT_LOAD", RAM);
>> + REGION_ALIAS ("REGION_RODATA", RAM);
>> + REGION_ALIAS ("REGION_RODATA_LOAD", RAM);
>> + REGION_ALIAS ("REGION_DATA", RAM);
>> + REGION_ALIAS ("REGION_DATA_LOAD", RAM);
>> + REGION_ALIAS ("REGION_FAST_TEXT", RAM);
>> + REGION_ALIAS ("REGION_FAST_TEXT_LOAD", RAM);
>> + REGION_ALIAS ("REGION_FAST_DATA", RAM);
>> + REGION_ALIAS ("REGION_FAST_DATA_LOAD", RAM);
>> + REGION_ALIAS ("REGION_BSS", RAM);
>> + REGION_ALIAS ("REGION_WORK", RAM);
>> + REGION_ALIAS ("REGION_STACK", RAM);
>> + REGION_ALIAS ("REGION_NOCACHE", RAM);
>> + REGION_ALIAS ("REGION_NOCACHE_LOAD", RAM);
>> + bsp_stack_abt_size = DEFINED (bsp_stack_abt_size) ? bsp_stack_abt_size : 1024;
>> + bsp_section_rwbarrier_align = DEFINED (bsp_section_rwbarrier_align) ? bsp_section_rwbarrier_align : 1M;
>> + bsp_vector_table_in_start_section = 1;
>> + INCLUDE linkcmds.armv4
>> +copyrights:
>> +enabled-by: true
>> +install-path: ${BSP_LIBDIR}
>> +links: []
>> +target: linkcmds
>> +type: build
>> diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/optclkfastidle.yml b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optclkfastidle.yml
>> index 0000000000..e303a8bf9f
>> --- /dev/null
>> +++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optclkfastidle.yml
>> @@ -0,0 +1,21 @@
>> +actions:
>> +- get-boolean: null
>> +- define-condition: null
>> +build-type: option
>> +copyrights:
>> +- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
>> +default:
>> +- enabled-by:
>> + - arm/lm3s6965_qemu
>> + - arm/realview_pbx_a9_qemu
>> + - arm/xilinx_zynq_a9_qemu
>> + value: true
>> +- enabled-by: true
>> + value: false
>> +description: |
>> + This sets a mode where the time runs as fast as possible when a clock ISR occurs while the IDLE thread is executing. This can significantly reduce simulation times.
>> +enabled-by: true
>> +links: []
>> +name: CLOCK_DRIVER_USE_FAST_IDLE
>> +type: build
>> diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/optclkuart.yml b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optclkuart.yml
>> index 0000000000..77c8f30fff
>> --- /dev/null
>> +++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optclkuart.yml
>> @@ -0,0 +1,17 @@
>> +actions:
>> +- get-integer: null
>> +- define: null
>> +build-type: option
>> +copyrights:
>> +default:
>> +- enabled-by: true
>> + value: 100000000
>> +description: |
>> + Zynq UART clock frequency in Hz
>> +enabled-by: true
>> +format: '{}'
>> +links: []
>> +name: ZYNQ_CLOCK_UART
>> +type: build
>> diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/optconirq.yml b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optconirq.yml
>> index 0000000000..ea13fa4561
>> --- /dev/null
>> +++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optconirq.yml
>> @@ -0,0 +1,16 @@
>> +actions:
>> +build-type: option
>> +copyrights:
>> +default:
>> +- enabled-by: true
>> + value: true
>> +description: |
>> + use interrupt driven mode for console devices (used by default)
>> +enabled-by: true
>> +links: []
>> +name: ZYNQ_CONSOLE_USE_INTERRUPTS
>> +type: build
>> diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/optint0len.yml b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optint0len.yml
>> index 0000000000..774d2c9269
>> --- /dev/null
>> +++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optint0len.yml
>> @@ -0,0 +1,18 @@
>> +actions:
>> +- assert-uint32: null
>> +- env-assign: null
>> +- format-and-define: null
>> +build-type: option
>> +copyrights:
>> +default:
>> +- enabled-by: true
>> + value: 0x00010000
>> +description: ''
>> +enabled-by: true
>> +format: '{:#010x}'
>> +links: []
>> +name: ZYNQMP_RAM_INT_0_LENGTH
>> +type: build
>> diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/optint0ori.yml b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optint0ori.yml
>> index 0000000000..3fa03d3129
>> --- /dev/null
>> +++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optint0ori.yml
>> @@ -0,0 +1,18 @@
>> +actions:
>> +- env-assign: null
>> +build-type: option
>> +copyrights:
>> +default:
>> +- enabled-by: true
>> + value: 0x00000000
>> +description: ''
>> +enabled-by: true
>> +format: '{:#010x}'
>> +links: []
>> +name: ZYNQMP_RAM_INT_0_ORIGIN
>> +type: build
>> diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/optint1len.yml b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optint1len.yml
>> index 0000000000..f179142ed4
>> --- /dev/null
>> +++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optint1len.yml
>> @@ -0,0 +1,18 @@
>> +actions:
>> +- env-assign: null
>> +build-type: option
>> +copyrights:
>> +default:
>> +- enabled-by: true
>> + value: 0x00010000
>> +description: ''
>> +enabled-by: true
>> +format: '{:#010x}'
>> +links: []
>> +name: ZYNQMP_RAM_INT_1_LENGTH
>> +type: build
>> diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/optint1ori.yml b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optint1ori.yml
>> index 0000000000..37bbf4fcd0
>> --- /dev/null
>> +++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optint1ori.yml
>> @@ -0,0 +1,18 @@
>> +actions:
>> +- env-assign: null
>> +build-type: option
>> +copyrights:
>> +default:
>> +- enabled-by: true
>> + value: 0x00020000
>> +description: ''
>> +enabled-by: true
>> +format: '{:#010x}'
>> +links: []
>> +name: ZYNQMP_RAM_INT_1_ORIGIN
>> +type: build
>> diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/optprocunitrpu.yml b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optprocunitrpu.yml
>> index 0000000000..9298808b2a
>> --- /dev/null
>> +++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optprocunitrpu.yml
>> @@ -0,0 +1,17 @@
>> +actions:
>> +build-type: option
>> +copyrights:
>> +default:
>> +- enabled-by: true
>> + value: true
>> +description: |
>> + Sets the target processing unit to the RPU (R5F) cores.
>> +enabled-by: true
>> +format: '{}'
>> +links: []
>> +name: ZYNQMP_PROC_UNIT_RPU
>> +type: build
>> diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/optramlen.yml b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optramlen.yml
>> index 0000000000..5cb5e805cf
>> --- /dev/null
>> +++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optramlen.yml
>> @@ -0,0 +1,21 @@
>> +actions:
>> +- env-assign: null
>> +build-type: option
>> +copyrights:
>> +default:
>> +- enabled-by: arm/xilinx_zynqmp_ultra96
>> + value: 0x80000000
>> +- enabled-by: true
>> + value: 0x10000000
>> +description: |
>> + override a BSP's default RAM length
>> +enabled-by: true
>> +format: '{:#010x}'
>> +links: []
>> +name: ZYNQMP_RAM_LENGTH
>> +type: build
>> diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/optramori.yml b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optramori.yml
>> index 0000000000..6269b662e0
>> --- /dev/null
>> +++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optramori.yml
>> @@ -0,0 +1,19 @@
>> +actions:
>> +- assert-aligned: 1048576
>> +- env-assign: null
>> +build-type: option
>> +copyrights:
>> +default:
>> +- enabled-by: true
>> + value: 0x00100000
>> +description: ''
>> +enabled-by: true
>> +format: '{:#010x}'
>> +links: []
>> +name: ZYNQMP_RAM_ORIGIN
>> +type: build
>> diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/optresetvec.yml b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optresetvec.yml
>> index 0000000000..bac5c79627
>> --- /dev/null
>> +++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optresetvec.yml
>> @@ -0,0 +1,16 @@
>> +actions:
>> +build-type: option
>> +copyrights:
>> +default:
>> +- enabled-by: true
>> + value: false
>> +description: |
>> + reset vector address for BSP start
>> +enabled-by: true
>> +links: []
>> +name: BSP_START_RESET_VECTOR
>> +type: build
>> diff --git a/spec/build/bsps/arm/xilinx-zynqmp/bspxilinxzynqmp.yml b/spec/build/bsps/arm/xilinx-zynqmp/bspxilinxzynqmp.yml
>> index 216cc88360..f14efc2957 100644
>> --- a/spec/build/bsps/arm/xilinx-zynqmp/bspxilinxzynqmp.yml
>> +++ b/spec/build/bsps/arm/xilinx-zynqmp/bspxilinxzynqmp.yml
>> @@ -62,6 +62,8 @@ links:
>> uid: optramori
>> uid: optresetvec
>> + uid: optprocunitapu
>> uid: ../../obj
>> diff --git a/spec/build/bsps/arm/xilinx-zynqmp/optprocunitapu.yml b/spec/build/bsps/arm/xilinx-zynqmp/optprocunitapu.yml
>> index 0000000000..6040891123
>> --- /dev/null
>> +++ b/spec/build/bsps/arm/xilinx-zynqmp/optprocunitapu.yml
>> @@ -0,0 +1,17 @@
>> +actions:
>> +build-type: option
>> +copyrights:
>> +default:
>> +- enabled-by: true
>> + value: true
>> +description: |
>> + Sets the target processing unit to the APU (A53) cores.
>> +enabled-by: true
>> +format: '{}'
>> +links: []
>> +name: ZYNQMP_PROC_UNIT_APU
>> +type: build
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230614/4b2ea486/attachment-0001.htm>
