[PATCH] rtemsbsd/versal_slcr: Fix Versal GEM clock set
aaron.nyholm at unfoldedeffective.com
Thu Jun 15 05:48:36 UTC 2023
From: Aaron Nyholm <aaron.nyholm at southerninnovation.com>
rtemsbsd/sys/arm64/xilinx/versal_slcr.c | 34 ++++++++++++++++++++++---
rtemsbsd/sys/arm64/xilinx/versal_slcr.h | 6 +++++
2 files changed, 36 insertions(+), 4 deletions(-)
diff --git a/rtemsbsd/sys/arm64/xilinx/versal_slcr.c b/rtemsbsd/sys/arm64/xilinx/versal_slcr.c
index 74ebde91..1f4d48bc 100644
--- a/rtemsbsd/sys/arm64/xilinx/versal_slcr.c
+++ b/rtemsbsd/sys/arm64/xilinx/versal_slcr.c
@@ -78,10 +78,13 @@ SYSCTL_NODE(_hw, OID_AUTO, versal, CTLFLAG_RD, 0, "Xilinx Versal ACAP SLCR");
int
cgem_set_ref_clk(int unit, int frequency)
struct versal_slcr_softc *sc = versal_slcr_softc_p;
int div, last_error = 0;
- uint64_t clk_ctrl, pll_ctrl;
+ uint64_t clk_ctrl, pll_ctrl, to_xpd_ctrl;
uint32_t clk_ctrl_val, pll_ctrl_val, pll_freq, pll_reset, pll_bypass;
+ uint32_t clk_src_sel, to_xpd_ctrl_val, to_xpd_div, to_xpd_freq;
if (!sc)
return (-1);
@@ -126,15 +129,38 @@ cgem_set_ref_clk(int unit, int frequency)
/* Apply divider */
- pll_freq >>= (pll_ctrl_val & VERSAL_SLCR_PLL_CTRL_DIV_MASK) >> VERSAL_SLCR_PLL_CTRL_DIV_SHIFT;
+ pll_freq >>= (pll_ctrl_val & VERSAL_SLCR_PLL_CTRL_DIV_MASK) >> VERSAL_SLCR_PLL_CTRL_DIV_SHIFT;
+ /* Check if routed through {X}PLL_TO_XPD_CLK to GEM{unit}_REF_CLK and adjust */
+ clk_src_sel = (clk_ctrl_val & VERSAL_SLCR_GEM_CLK_CTRL_SRCSEL_MASK);
+ to_xpd_ctrl = 0;
+ if (clk_src_sel == VERSAL_SLCR_GEM_CLK_CTRL_SRCSEL_P_PLL)
+ to_xpd_ctrl = VERSAL_SLCR_PPLL_TO_XPD_CTRL;
+ } else if (clk_src_sel == VERSAL_SLCR_GEM_CLK_CTRL_SRCSEL_N_PLL)
+ to_xpd_ctrl = VERSAL_SLCR_NPLL_TO_XPD_CTRL;
+ if (to_xpd_ctrl != 0) {
+ to_xpd_ctrl_val = RD4(sc, to_xpd_ctrl);
+ to_xpd_div = (to_xpd_ctrl_val & VERSAL_SLCR_XPD_CLK_CTRL_DIVISOR_MASK);
+ to_xpd_div = to_xpd_div >> VERSAL_SLCR_XPD_CTRL_DIV_SHIFT;
+ if (to_xpd_div == 0) {
+ to_xpd_div = 1;
+ to_xpd_freq = pll_freq / to_xpd_div;
+ } else {
+ to_xpd_freq = pll_freq;
/* Find suitable divisor. Linear search, not the fastest method but hey.
for (div = 1; div <= VERSAL_SLCR_GEM_CLK_CTRL_DIVISOR_MAX; div++) {
- int div_freq = pll_freq / div;
+ int div_freq = to_xpd_freq / div;
int error = abs(frequency - div_freq);
if (error >= last_error && last_error != 0) {
- div--;
+ div--;
break;
last_error = error;
diff --git a/rtemsbsd/sys/arm64/xilinx/versal_slcr.h b/rtemsbsd/sys/arm64/xilinx/versal_slcr.h
index e1c967ac..121c1e0a 100644
--- a/rtemsbsd/sys/arm64/xilinx/versal_slcr.h
+++ b/rtemsbsd/sys/arm64/xilinx/versal_slcr.h
@@ -78,6 +78,12 @@
#define VERSAL_SLCR_GEM_CLK_CTRL_SRCSEL_R_PLL (1<<0)
#define VERSAL_SLCR_GEM_CLK_CTRL_SRCSEL_N_PLL (3<<0)
+#define VERSAL_SLCR_PPLL_TO_XPD_CTRL (VERSAL_SLCR_CRF_OFFSET + 0x100)
+#define VERSAL_SLCR_NPLL_TO_XPD_CTRL (VERSAL_SLCR_CRF_OFFSET + 0x104)
+#define VERSAL_SLCR_XPD_CLK_CTRL_DIVISOR_MAX 0x3ff
+#define VERSAL_SLCR_XPD_CLK_CTRL_DIVISOR_MASK (VERSAL_SLCR_XPD_CLK_CTRL_DIVISOR_MAX<<8)
+#define VERSAL_SLCR_XPD_CTRL_DIV_SHIFT 8
#define VERSAL_DEFAULT_PS_CLK_FREQUENCY 33333333
#ifdef _KERNEL
2.25.1
