[PATCH] rtemsbsd/versal_slcr: Fix Versal GEM clock set
Will
nyphbl8d at gmail.com
Thu Jun 15 12:15:15 UTC 2023
This looks good as far as the functional content is concerned. As a nit, it
looks like some unnecessary newlines were added in cgem_set_ref_clk() and
the added if() conditional braces are inconsistent in their formatting so
feel free to tweak those before commit.
On Thu, Jun 15, 2023 at 12:48 AM <aaron.nyholm at unfoldedeffective.com> wrote:
> From: Aaron Nyholm <aaron.nyholm at southerninnovation.com>
> rtemsbsd/sys/arm64/xilinx/versal_slcr.c | 34 ++++++++++++++++++++++---
> rtemsbsd/sys/arm64/xilinx/versal_slcr.h | 6 +++++
> 2 files changed, 36 insertions(+), 4 deletions(-)
> diff --git a/rtemsbsd/sys/arm64/xilinx/versal_slcr.c
> b/rtemsbsd/sys/arm64/xilinx/versal_slcr.c
> index 74ebde91..1f4d48bc 100644
> --- a/rtemsbsd/sys/arm64/xilinx/versal_slcr.c
> +++ b/rtemsbsd/sys/arm64/xilinx/versal_slcr.c
> @@ -78,10 +78,13 @@ SYSCTL_NODE(_hw, OID_AUTO, versal, CTLFLAG_RD, 0,
> "Xilinx Versal ACAP SLCR");
> int
> cgem_set_ref_clk(int unit, int frequency)
> struct versal_slcr_softc *sc = versal_slcr_softc_p;
> int div, last_error = 0;
> - uint64_t clk_ctrl, pll_ctrl;
> + uint64_t clk_ctrl, pll_ctrl, to_xpd_ctrl;
> uint32_t clk_ctrl_val, pll_ctrl_val, pll_freq, pll_reset,
> pll_bypass;
> + uint32_t clk_src_sel, to_xpd_ctrl_val, to_xpd_div, to_xpd_freq;
> if (!sc)
> return (-1);
> @@ -126,15 +129,38 @@ cgem_set_ref_clk(int unit, int frequency)
> /* Apply divider */
> - pll_freq >>= (pll_ctrl_val & VERSAL_SLCR_PLL_CTRL_DIV_MASK) >>
> VERSAL_SLCR_PLL_CTRL_DIV_SHIFT;
> + pll_freq >>= (pll_ctrl_val & VERSAL_SLCR_PLL_CTRL_DIV_MASK) >>
> + /* Check if routed through {X}PLL_TO_XPD_CLK to GEM{unit}_REF_CLK
> and adjust */
> + clk_src_sel = (clk_ctrl_val &
> VERSAL_SLCR_GEM_CLK_CTRL_SRCSEL_MASK);
> + to_xpd_ctrl = 0;
> + if (clk_src_sel == VERSAL_SLCR_GEM_CLK_CTRL_SRCSEL_P_PLL)
> + to_xpd_ctrl = VERSAL_SLCR_PPLL_TO_XPD_CTRL;
> + } else if (clk_src_sel == VERSAL_SLCR_GEM_CLK_CTRL_SRCSEL_N_PLL)
> + to_xpd_ctrl = VERSAL_SLCR_NPLL_TO_XPD_CTRL;
> + if (to_xpd_ctrl != 0) {
> + to_xpd_ctrl_val = RD4(sc, to_xpd_ctrl);
> + to_xpd_div = (to_xpd_ctrl_val &
> VERSAL_SLCR_XPD_CLK_CTRL_DIVISOR_MASK);
> + to_xpd_div = to_xpd_div >> VERSAL_SLCR_XPD_CTRL_DIV_SHIFT;
> + if (to_xpd_div == 0) {
> + to_xpd_div = 1;
> + to_xpd_freq = pll_freq / to_xpd_div;
> + } else {
> + to_xpd_freq = pll_freq;
> /* Find suitable divisor. Linear search, not the fastest method
> but hey.
> for (div = 1; div <= VERSAL_SLCR_GEM_CLK_CTRL_DIVISOR_MAX; div++) {
> - int div_freq = pll_freq / div;
> + int div_freq = to_xpd_freq / div;
> int error = abs(frequency - div_freq);
> if (error >= last_error && last_error != 0) {
> - div--;
> + div--;
> break;
> last_error = error;
> diff --git a/rtemsbsd/sys/arm64/xilinx/versal_slcr.h
> b/rtemsbsd/sys/arm64/xilinx/versal_slcr.h
> index e1c967ac..121c1e0a 100644
> --- a/rtemsbsd/sys/arm64/xilinx/versal_slcr.h
> +++ b/rtemsbsd/sys/arm64/xilinx/versal_slcr.h
> @@ -78,6 +78,12 @@
> #define VERSAL_SLCR_GEM_CLK_CTRL_SRCSEL_R_PLL (1<<0)
> #define VERSAL_SLCR_GEM_CLK_CTRL_SRCSEL_N_PLL (3<<0)
> +#define VERSAL_SLCR_PPLL_TO_XPD_CTRL (VERSAL_SLCR_CRF_OFFSET +
> 0x100)
> +#define VERSAL_SLCR_NPLL_TO_XPD_CTRL (VERSAL_SLCR_CRF_OFFSET +
> 0x104)
> +#define VERSAL_SLCR_XPD_CLK_CTRL_DIVISOR_MAX 0x3ff
> +#define VERSAL_SLCR_XPD_CLK_CTRL_DIVISOR_MASK
> (VERSAL_SLCR_XPD_CLK_CTRL_DIVISOR_MAX<<8)
> +#define VERSAL_SLCR_XPD_CTRL_DIV_SHIFT 8
> #define VERSAL_DEFAULT_PS_CLK_FREQUENCY 33333333
> #ifdef _KERNEL
> 2.25.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230615/6918dff9/attachment-0001.htm>
