bsps/xilinx-zynqmp : Add BSP for RPU
Aaron Nyholm
aaron.nyholm at unfoldedeffective.com
Thu Jun 15 06:59:22 UTC 2023
This looks exciting.
As for Versal support from Xilinx's Docs "RPU
The real-time processing unit (RPU) Arm Cortex-R5F processor has faster clocking frequencies than the Zynq UltraScale+ MPSoC. The Versal Arm Cortex-R5F processor supports Vector Floating-Point v3 (VFPv3) whereas the Zynq UltraScale+ MPSoC Arm Cortex-R5F processor supports VFPv2." https://docs.xilinx.com/r/en-US/ug1273-versal-acap-design/RPU
VFPv3 is backwards compatible with VFPv2 (https://developer.arm.com/documentation/ddi0344/d/programmer-s-model/vfpv3-architecture?lang=en).
So hopefully reuse for the Versal should relativity straight forward.
Side note, even though Xilinx says the R5F in the ZynqMP has VFPv2, ARM says to compile with vfpv3_d16 like what is already in the BSP (https://developer.arm.com/documentation/dui0472/i/CIHGDBHC).
Thanks, Aaron
------- Original Message -------
On Thursday, June 15th, 2023 at 9:17 AM, Chris Johns <chrisj at rtems.org> wrote:
> On 14/6/2023 6:08 pm, Philip Kirkpatrick wrote:
> > This patch adds support for running RTEMS on the RPU (cortex R5) cores of the
> > ZynqMP.
> Thanks for submitting this BSP. It is exciting to see this work and support
> being added.
> How different are the ZynqMP RPU cores and the ones on the Versal?
> I have not looked in detail but I know they are both R5 devices and I think we
> should be able to reuse this support. Is placing the RPU pieces under the ZynqMP
> sources what we want or should we consider how we would reuse the RPU BSP on
> other Xilinx devices?
> I am leading with this question without reviewing the sources in detail so I
> apologise for this. I am happy to look at Versal support so I am not asking that
> to be done.
> Chris
> devel mailing list
> devel at rtems.org
