BSP .inc files and .cfg files
Philip Kirkpatrick p.kirkpatrick at reflexaerospace.com
Fri Jun 16 08:18:37 UTC 2023
For the RPU patch, I'll add removing this to my next pass at it.
On Fri, Jun 16, 2023 at 6:37 AM Sebastian Huber <
> On 16.06.23 06:35, Chris Johns wrote:
> > On 16/6/2023 2:33 pm, Sebastian Huber wrote:
> >> On 16.06.23 03:46, Chris Johns wrote:
> >>> On 16/6/2023 9:04 am, Joel Sherrill wrote:
> >>>> On Thu, Jun 15, 2023 at 5:41 PM Chris Johns <chrisj at rtems.org
> >>>> <mailto:chrisj at rtems.org>> wrote:
> >>>>       Hi,
> >>>>       Reviewing the RPU patch I noticed a .inc file being added and I
> wondered
> >>>> why so
> >>>>       I checked the sources and to my surprise found:
> >>>>       rtems.git $ find bsps -name \*.inc
> >>>>       bsps/v850/gdbv850sim/config/v850sim.inc
> >>>>       bsps/m68k/genmcf548x/config/genmcf548x.inc
> >>>>       bsps/m68k/gen68340/include/m68340.inc
> >>>>       bsps/m68k/gen68340/include/m68349.inc
> >>>>       bsps/arm/altera-cyclone-v/config/altcycv.inc
> >>>>       bsps/arm/raspberrypi/config/raspberrypi.inc
> >>>>       bsps/arm/lpc32xx/config/lpc32xx.inc
> >>>>       bsps/arm/beagle/config/beagle.inc
> >>>>       bsps/arm/tms570/config/tms570ls3137.inc
> >>>>       bsps/arm/xilinx-zynqmp/config/xilinx_zynqmp.inc
> >>>>       bsps/arm/xilinx-zynq/config/xilinx_zynq.inc
> >>>>       bsps/arm/lpc24xx/config/lpc17xx.inc
> >>>>       bsps/arm/lpc24xx/config/lpc40xx.inc
> >>>>       bsps/arm/lpc24xx/config/lpc24xx.inc
> >>>>       bsps/arm/lm3s69xx/config/lm3s69xx.inc
> >>>>       bsps/powerpc/gen5200/config/gen5200.inc
> >>>>       bsps/powerpc/tqm8xx/config/tqm8xx.inc
> >>>>       bsps/powerpc/mpc55xxevb/config/mpc55xx.inc
> >>>>       bsps/powerpc/qoriq/config/qoriq.inc
> >>>>       bsps/powerpc/gen83xx/config/gen83xx.inc
> >>>> These likely can. Thinking back, we have cfg files for every BSP
> >>>> variant within a family. They often set a variable like CPU and
> CPU_CFLAGS
> >>>> and included a shared .inc file. These all appear to be from BSPs
> which
> >>>> had variants. I think they are remnants and missed when the .cfg files
> >>>> were
> >>>> Would like someone to concur.
> >>>>       And for .cfg there is:
> >>>>       rtems.git $ find bsps -name \*.cfg | wc -l
> >>>>            191
> >>>> Are these installed and used by the application Makefile system. If
> so, no.
> >>> I cannot see any references in spec but Sebastian is the best person
> to answer
> >>> this.
> >> They are definitely not used or installed. I think we still have then
> since they
> >> document the post-link actions which are not yet supported by the new
> build system.
> > Ah yes, thanks. What if the files are collected and archived?
> I think we should just remove them. We can use the RTEMS 5 branch to
> look up the post-link actions if needed.
> > The RPU BSP is adding a new one. Is this what we want to see happen?
> No, we don't want to see new ones.
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230616/37246167/attachment-0001.htm>
