[PATCH rtems] Remove unused _IO_Relax
Joel Sherrill
joel at rtems.org
Wed Jun 28 17:02:43 UTC 2023
On Wed, Jun 28, 2023 at 11:29 AM Sebastian Huber <
> On 28.06.23 18:17, Joel Sherrill wrote:
> > On Wed, Jun 28, 2023 at 11:07 AM Sebastian Huber
> > <sebastian.huber at embedded-brains.de
> > <mailto:sebastian.huber at embedded-brains.de>> wrote:
> > On 28.06.23 18:05, Joel Sherrill wrote:
> > > The only use was in a test.
> > This function is used by this patch set:
> > https://lists.rtems.org/pipermail/devel/2023-June/075497.html
> > <https://lists.rtems.org/pipermail/devel/2023-June/075497.html>
> > (1) Not in the source repository
> I didn't expect that the BSP update integration takes about two years.
> > (2) Even if it was, this code does not belong in the score. It looks
> > more like BSP support code that some drivers need.
> Where would you place this code?
If you want it on the cpukit side, dev/shared maybe. Otherwise, bsps/shared.
I think it's bsp/driver support code.
--joel
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax: +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230628/e44bd187/attachment-0001.htm>
