[PATCH] bsps/riscv: Clear interrupt complete before disable
Padmarao.Begari at microchip.com
Mon Mar 6 08:37:02 UTC 2023
Hi Sebastian,
> On Mon, 2023-03-06 at 08:01 +0100, Sebastian Huber wrote:
> Hello Padmarao,
> On 03.03.23 15:55, Padmarao.Begari at microchip.com wrote:
> > > On Thu, 2023-03-02 at 15:18 +0100, Sebastian Huber wrote:
> > > On 27.02.23 16:51, Padmarao Begari wrote:
> > > > The interrupt complete should clear with the interrupt
> > > > number before disabling the interrupt in the PLIC to
> > > > get the next interrupt.
> > > Which problem does this patch address?
> > The problem occurs when the interrupt register(enabled) in the
> > RTEMS-
> > LIBBSD drivers and want to serve the interrupt subroutine in the
> > RTEMS.
> > Example : CGEM driver
> > When the application running to test the CGEM driver with RTEMS +
> > RTEMS-LIBBSD, The interrupt is occurred while transmiting the
> > ethernet
> > pocket, the RTEMS is received the interrupt but not served with the
> > register interrupt subroutine instead it disable the interrupt and
> > set
> > the "RTEMS_EVENT_SYSTEM_SERVER", while completing the ISR it is
> > clearing the interrupt complete register but there is no effect and
> > the
> > next transmit pocket intereupt is not occurred because the
> > interrupt is
> > disabled before the interrupt complete clear.
> > RISC-V interrupt stacktrace
> > _RISCV_Exception_handler()
> > _RISCV_Interrupt_dispatch()
> > bsp_interrupt_handler_dispatch_unchecked()
> > bsp_interrupt_dispatch_entries()
> > ( *entry->handler )( entry->arg ); ->
> > bsp_interrupt_server_trigger()
> > bsp_interrupt_is_valid_vector()
> > bsp_interrupt_vector_disable()
> > rtems_event_system_send()
> The claim complete register is written after the interrupt handler
> dispatch:
> while ((interrupt_index = plic_hart_regs->claim_complete) != 0)
> bsp_interrupt_handler_dispatch(
> RISCV_INTERRUPT_VECTOR_EXTERNAL(interrupt_index)
> plic_hart_regs->claim_complete = interrupt_index;
> If you write to the claim complete register also in the interrupt
> disable function, then this write is done twice.
Yes but no impact on second write.
> The interrupt disable function may be used in other contexts as well
> so
> doing a write to the claim complete register may have unexpected side
> effects.
> We should first figure out why the current implementation which works
> with several other interrupt controllers doesn't work with the PLIC.
Current Implemtation is working fine for UART, Timer because the ISR is
installed at the RTEMS source and when the interrupt is occured it is
going to call the ISR and clear the interrupt complete but not disable
the interrupt.
> Is
> the claim complete message ignored if the interrupt is disabled?
Yes.
Regards
Padmarao
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax: +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas
> Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
