[PATCH] bsps/riscv: Clear interrupt complete before disable
Padmarao.Begari at microchip.com
Tue Mar 14 12:31:39 UTC 2023
Hi Sebastian,
>On Mon, 2023-03-06 at 14:11 +0100, Sebastian Huber wrote:
> On 06.03.23 13:00, Padmarao.Begari at microchip.com wrote:
> > > On Mon, 2023-03-06 at 11:19 +0100, Sebastian Huber wrote:
> > > On 06.03.23 10:24,Padmarao.Begari at microchip.com wrote:
> > > > Hi Sebastian,
> > > > > On Mon, 2023-03-06 at 09:41 +0100, Sebastian Huber wrote:
> > > > > On 06.03.23 09:37,Padmarao.Begari at microchip.com wrote:
> > > > > > > Is
> > > > > > > the claim complete message ignored if the interrupt is
> > > > > > > disabled?
> > > > > > Yes.
> > > > > Is this an intended and documented behaviour of the PLIC?
> > > > Not documented
> > > Is this a common PLIC behaviour or just the case for the
> > > MicroChip
> > > implementation?
> > It's a common PLIC behaviour.
> It is not implemented in the Qemu PLIC emulation:
> https://github.com/qemu/qemu/blob/master/hw/intc/sifive_plic.c#L242
> Where do I see this behaviour in a PLIC implementation, for example:
> https://github.com/lowRISC/opentitan/tree/master/hw/ip_templates/rv_plic
> That the interrupt completion depends on the interrupt enable/disable
> status is quite unusual.
https://github.com/riscv/riscv-plic-spec/blob/master/riscv-plic.adoc#8-interrupt-completion
The interrupt is completed only when the interrupt is enabled but not
when disabled.
Can we clear the interrupt before calling the interrupt handler? like
below
https://github.com/RTEMS/rtems/blob/master/bsps/riscv/riscv/irq/irq.c#L90
while ((interrupt_index = plic_hart_regs->claim_complete) != 0) {
+ plic_hart_regs->claim_complete = interrupt_index;
bsp_interrupt_handler_dispatch(
RISCV_INTERRUPT_VECTOR_EXTERNAL(interrupt_index)
- plic_hart_regs->claim_complete = interrupt_index;
Also refer
https://github.com/psherman42/Demonstrating-MTVEC/blob/main/start.s#L307
Regards
Padmarao
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax: +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas
> Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
