[PATCH rtems-tools] rtems-bsps-riscv.ini: Update list to drop medany and add BSPs
Hesham Almatary heshamelmatary at gmail.com
Tue Mar 14 14:22:36 UTC 2023
On Tue, 14 Mar 2023 at 14:14, Joel Sherrill <joel at rtems.org> wrote:
>  config/rtems-bsps-riscv.ini | 16 +++++++++++-----
>  1 file changed, 11 insertions(+), 5 deletions(-)
> diff --git a/config/rtems-bsps-riscv.ini b/config/rtems-bsps-riscv.ini
> index 804245e..816675f 100644
> --- a/config/rtems-bsps-riscv.ini
> +++ b/config/rtems-bsps-riscv.ini
> @@ -1,6 +1,7 @@
>  # RTEMS Tools Project (http://www.rtems.org/)
>  # Copyright 2018 embedded brains GmbH
> +# Copyright 2022 OAR Corporation
>  # All rights reserved.
>  # This file is part of the RTEMS Tools package in 'rtems-bsp-builder'.
> @@ -22,8 +23,13 @@
>  [riscv]
>  bsps = frdme310arty,
> -       griscv, grv32i, grv32im, grv32imac, grv32imafdc,
> -       rv32iac, rv32i, rv32imac, rv32imafc, rv32imafdc, rv32imafd, rv32im,
> -       rv64imac, rv64imac_medany, rv64imafdc, rv64imafd, rv64imafdc_medany,
> -       rv64imafd_medany
> -exclude-smp = rv32i, rv32im
> +    griscv, grv32i, grv32im, grv32imac, grv32imafdc,
> +    mpfs64imafdc,
> +    noel32im, noel32imafd, noel64imac, noel64imafd, noel64imafdc,
> +    rv32i, rv32iac, rv32im, rv32imac, rv32imafc, rv32imafd, rv32imafdc,
Could we make sure that only variants in multilib are here? For
example, there shouldn't be rv32imafdc. I submitted a similar patch
before here [1], please feel free to use it as a reference as in to
what multilib variants should be used here.
[1] https://lists.rtems.org/pipermail/devel/2023-February/074455.html
> +    rv64imac, rv64imafd, rv64imafdc
> +exclude-smp = frdme310arty,
> +    grv32i, grv32im,
> +    noel32im,
> +    rv32i, rv32im
> 1.8.3.1
> devel mailing list
> devel at rtems.org
Regards,
Hesham
