[PATCH rtems-tools] rtems-bsps-riscv.ini: Update list to drop medany and add BSPs
Joel Sherrill
joel at rtems.org
Tue Mar 14 15:03:35 UTC 2023
On Tue, Mar 14, 2023 at 9:23 AM Hesham Almatary <heshamelmatary at gmail.com>
wrote:
> On Tue, 14 Mar 2023 at 14:14, Joel Sherrill <joel at rtems.org> wrote:
> > config/rtems-bsps-riscv.ini | 16 +++++++++++-----
> > 1 file changed, 11 insertions(+), 5 deletions(-)
> > diff --git a/config/rtems-bsps-riscv.ini b/config/rtems-bsps-riscv.ini
> > index 804245e..816675f 100644
> > --- a/config/rtems-bsps-riscv.ini
> > +++ b/config/rtems-bsps-riscv.ini
> > @@ -1,6 +1,7 @@
> > # RTEMS Tools Project (http://www.rtems.org/)
> > # Copyright 2018 embedded brains GmbH
> > +# Copyright 2022 OAR Corporation
> > # All rights reserved.
> > # This file is part of the RTEMS Tools package in 'rtems-bsp-builder'.
> > @@ -22,8 +23,13 @@
> > [riscv]
> > bsps = frdme310arty,
> > - griscv, grv32i, grv32im, grv32imac, grv32imafdc,
> > - rv32iac, rv32i, rv32imac, rv32imafc, rv32imafdc, rv32imafd,
> rv32im,
> > - rv64imac, rv64imac_medany, rv64imafdc, rv64imafd,
> rv64imafdc_medany,
> > - rv64imafd_medany
> > -exclude-smp = rv32i, rv32im
> > + griscv, grv32i, grv32im, grv32imac, grv32imafdc,
> > + mpfs64imafdc,
> > + noel32im, noel32imafd, noel64imac, noel64imafd, noel64imafdc,
> > + rv32i, rv32iac, rv32im, rv32imac, rv32imafc, rv32imafd, rv32imafdc,
> Could we make sure that only variants in multilib are here? For
> example, there shouldn't be rv32imafdc. I submitted a similar patch
> before here [1], please feel free to use it as a reference as in to
> what multilib variants should be used here.
This list is based on what is currently in RTEMS. Kinsey and I started with
the
list reported by "rtems-bsps -a riscv" and reviewed which has SMP as an
option.
Given that you know the riscv much better, I would politely request that
you let
me push this and then you follow up with patches to remove those BSPs from
rtems and rtems-tools.
--joel
> [1] https://lists.rtems.org/pipermail/devel/2023-February/074455.html
> > + rv64imac, rv64imafd, rv64imafdc
> > +exclude-smp = frdme310arty,
> > + grv32i, grv32im,
> > + noel32im,
> > + rv32i, rv32im
> > 1.8.3.1
> > devel mailing list
> > devel at rtems.org
> Regards,
> Hesham
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230314/42fa5a7b/attachment.htm>
