[PATCH rtems-tools] rtems-bsps-riscv.ini: Update list to drop medany and add BSPs
Hesham Almatary
heshamelmatary at gmail.com
Tue Mar 14 15:51:12 UTC 2023
On Tue, 14 Mar 2023 at 15:03, Joel Sherrill <joel at rtems.org> wrote:
> On Tue, Mar 14, 2023 at 9:23 AM Hesham Almatary <heshamelmatary at gmail.com> wrote:
>> On Tue, 14 Mar 2023 at 14:14, Joel Sherrill <joel at rtems.org> wrote:
>> > config/rtems-bsps-riscv.ini | 16 +++++++++++-----
>> > 1 file changed, 11 insertions(+), 5 deletions(-)
>> > diff --git a/config/rtems-bsps-riscv.ini b/config/rtems-bsps-riscv.ini
>> > index 804245e..816675f 100644
>> > --- a/config/rtems-bsps-riscv.ini
>> > +++ b/config/rtems-bsps-riscv.ini
>> > @@ -1,6 +1,7 @@
>> > # RTEMS Tools Project (http://www.rtems.org/)
>> > # Copyright 2018 embedded brains GmbH
>> > +# Copyright 2022 OAR Corporation
>> > # All rights reserved.
>> > # This file is part of the RTEMS Tools package in 'rtems-bsp-builder'.
>> > @@ -22,8 +23,13 @@
>> > [riscv]
>> > bsps = frdme310arty,
>> > - griscv, grv32i, grv32im, grv32imac, grv32imafdc,
>> > - rv32iac, rv32i, rv32imac, rv32imafc, rv32imafdc, rv32imafd, rv32im,
>> > - rv64imac, rv64imac_medany, rv64imafdc, rv64imafd, rv64imafdc_medany,
>> > - rv64imafd_medany
>> > -exclude-smp = rv32i, rv32im
>> > + griscv, grv32i, grv32im, grv32imac, grv32imafdc,
>> > + mpfs64imafdc,
>> > + noel32im, noel32imafd, noel64imac, noel64imafd, noel64imafdc,
>> > + rv32i, rv32iac, rv32im, rv32imac, rv32imafc, rv32imafd, rv32imafdc,
>> Could we make sure that only variants in multilib are here? For
>> example, there shouldn't be rv32imafdc. I submitted a similar patch
>> before here [1], please feel free to use it as a reference as in to
>> what multilib variants should be used here.
> This list is based on what is currently in RTEMS. Kinsey and I started with the
> list reported by "rtems-bsps -a riscv" and reviewed which has SMP as an option.
> Given that you know the riscv much better, I would politely request that you let
> me push this and then you follow up with patches to remove those BSPs from
> rtems and rtems-tools.
Definitely yes, feel free to push, thanks for checking with me.
> --joel
>> [1] https://lists.rtems.org/pipermail/devel/2023-February/074455.html
>> > + rv64imac, rv64imafd, rv64imafdc
>> > +exclude-smp = frdme310arty,
>> > + grv32i, grv32im,
>> > + noel32im,
>> > + rv32i, rv32im
>> > 1.8.3.1
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
>> Regards,
>> Hesham
Regards,
Hesham
