[PATCH 13/34] bsp/leon3: Move system control register support
Sebastian Huber
Wed May 31 16:30:48 UTC 2023
Move, document, and reformat support functions from <leon.h> to
<bsp/leon3.h>.
bsps/sparc/leon3/include/bsp/leon3.h | 99 ++++++++++++++++++++++++++++
bsps/sparc/leon3/include/leon.h | 53 ---------------
bsps/sparc/leon3/start/bspsmp.c | 1 -
bsps/sparc/leon3/start/bspstart.c | 2 +-
bsps/sparc/leon3/start/cache.c | 2 +-
5 files changed, 101 insertions(+), 56 deletions(-)
diff --git a/bsps/sparc/leon3/include/bsp/leon3.h b/bsps/sparc/leon3/include/bsp/leon3.h
index 6f4c872aab..990628db7a 100644
--- a/bsps/sparc/leon3/include/bsp/leon3.h
+++ b/bsps/sparc/leon3/include/bsp/leon3.h
@@ -60,6 +60,105 @@ extern "C" {
extern uint32_t LEON3_Cpu_Index;
+ * @brief This constant represents the flush instruction cache flag of the LEON
+ * cache control register.
+#define LEON3_REG_CACHE_CTRL_FI 0x00200000U
+ * @brief This constant represents the data cache snooping enable flag of the
+ * LEON cache control register.
+#define LEON3_REG_CACHE_CTRL_DS 0x00800000U
+ * @brief Sets the ASI 0x2 system register value.
+ * @param addr is the address of the ASI 0x2 system register.
+ * @param val is the value to set.
+static inline void leon3_set_system_register( uint32_t addr, uint32_t val )
+ __asm__ volatile(
+ "sta %1, [%0] 2"
+ : "r" ( addr ), "r" ( val )
+ * @brief Gets the ASI 0x2 system register value.
+ * @return Returns the register value.
+static inline uint32_t leon3_get_system_register( uint32_t addr )
+ uint32_t val;
+ __asm__ volatile(
+ "lda [%1] 2, %0"
+ : "=r" ( val )
+ : "r" ( addr )
+ return val;
+ * @brief Sets the LEON cache control register value.
+static inline void leon3_set_cache_control_register( uint32_t val )
+ leon3_set_system_register( 0x0, val );
+ * @brief Gets the LEON cache control register value.
+static inline uint32_t leon3_get_cache_control_register( void )
+ return leon3_get_system_register( 0x0 );
+ * @brief Checks if the data cache snooping is enabled.
+ * @return Returns true, if the data cache snooping is enabled, otherwise
+ * false.
+static inline bool leon3_data_cache_snooping_enabled( void )
+ return ( leon3_get_cache_control_register() & LEON3_REG_CACHE_CTRL_DS ) != 0;
+ * @brief Gets the LEON instruction cache configuration register value.
+static inline uint32_t leon3_get_inst_cache_config_register( void )
+ return leon3_get_system_register( 0x8 );
+ * @brief Gets the LEON data cache configuration register value.
+static inline uint32_t leon3_get_data_cache_config_register( void )
+ return leon3_get_system_register( 0xc );
* @brief This lock serializes the interrupt controller access.
diff --git a/bsps/sparc/leon3/include/leon.h b/bsps/sparc/leon3/include/leon.h
index 69ae455f55..2856f71816 100644
--- a/bsps/sparc/leon3/include/leon.h
+++ b/bsps/sparc/leon3/include/leon.h
@@ -142,12 +142,6 @@ extern "C" {
#define LEON_REG_UART_CTRL_FA 0x80000000 /* FIFO Available */
#define LEON_REG_UART_CTRL_FA_BIT 31
- * The following defines the bits in the LEON Cache Control Register.
-#define LEON3_REG_CACHE_CTRL_FI 0x00200000 /* Flush instruction cache */
-#define LEON3_REG_CACHE_CTRL_DS 0x00800000 /* Data cache snooping */
/* LEON3 GP Timer */
extern volatile struct gptimer_regs *LEON3_Timer_Regs;
extern struct ambapp_dev *LEON3_Timer_Adev;
@@ -385,53 +379,6 @@ extern unsigned int leon3_timer_prescaler;
RTEMS_NO_RETURN void leon3_power_down_loop(void);
-static inline void leon3_set_system_register(uint32_t addr, uint32_t val)
- __asm__ volatile(
- "sta %1, [%0] 2"
- : "r" (addr), "r" (val)
-static inline uint32_t leon3_get_system_register(uint32_t addr)
- uint32_t val;
- __asm__ volatile(
- "lda [%1] 2, %0"
- : "=r" (val)
- : "r" (addr)
- return val;
-static inline void leon3_set_cache_control_register(uint32_t val)
- leon3_set_system_register(0x0, val);
-static inline uint32_t leon3_get_cache_control_register(void)
- return leon3_get_system_register(0x0);
-static inline bool leon3_data_cache_snooping_enabled(void)
- return leon3_get_cache_control_register() & LEON3_REG_CACHE_CTRL_DS;
-static inline uint32_t leon3_get_inst_cache_config_register(void)
- return leon3_get_system_register(0x8);
-static inline uint32_t leon3_get_data_cache_config_register(void)
- return leon3_get_system_register(0xc);
static inline uint32_t leon3_up_counter_low(void)
uint32_t asr23;
diff --git a/bsps/sparc/leon3/start/bspsmp.c b/bsps/sparc/leon3/start/bspsmp.c
index a8ad60b497..7f8496289a 100644
--- a/bsps/sparc/leon3/start/bspsmp.c
+++ b/bsps/sparc/leon3/start/bspsmp.c
@@ -18,7 +18,6 @@
#include <bsp/fatal.h>
#include <bsp/irq.h>
#include <bsp/leon3.h>
-#include <leon.h>
#include <rtems/bspIo.h>
#include <rtems/sysinit.h>
diff --git a/bsps/sparc/leon3/start/bspstart.c b/bsps/sparc/leon3/start/bspstart.c
index 61f888247f..dec92320e1 100644
--- a/bsps/sparc/leon3/start/bspstart.c
+++ b/bsps/sparc/leon3/start/bspstart.c
@@ -40,7 +40,7 @@
#include <bsp.h>
#include <bsp/irq-generic.h>
-#include <leon.h>
+#include <bsp/leon3.h>
#include <bsp/bootcard.h>
diff --git a/bsps/sparc/leon3/start/cache.c b/bsps/sparc/leon3/start/cache.c
index 0273ad1d45..676f591857 100644
--- a/bsps/sparc/leon3/start/cache.c
+++ b/bsps/sparc/leon3/start/cache.c
@@ -7,7 +7,7 @@
#include <amba.h>
-#include <leon.h>
#define CPU_CACHE_SUPPORT_PROVIDES_RANGE_FUNCTIONS
2.35.3
