Building RTEMS for an MC68F333
Joel Sherrill
joel at oarcorp.com
Thu Aug 21 15:44:38 UTC 1997
On Thu, 21 Aug 1997, Robin Kirkham wrote:
> The CPU32 does have a VBR; the 68000 is about the only one that does not.
> However, this problem does not relate to the VBR, but the existance or
> otherwise of a separate stack pointer for interrupts. The issue is, does
> RTEMS care?
Yes. If the CPU has a separate stack pointer, then you want to utilize
it.
> > Is this CPU32 core the same one used on the 68360 (QUICC) and 68340 ?
> > If it is then take a look at the configuration for the gen68360 BSP. It might be a
> > better match.
> As I understand things, it is the same CPU32 core as is found in the 68332,
> 340, 360, and others, unless Motorola are using CPU32 to mean "any slightly
> 683xx-ish thing". I don't think they do that.
My understanding is that there are basically 2 cores in the 683xx family
-- a 68000-ish one and CPU32. The cpu models are often developed by
different groups and feature sets vary accordingly. Get a Motorola
Semiconductor to show you the product guide sheet sometime. It makes more
sense then.
> I'll have a look at the other BSPs tomorrow, but my reading of the CPU
> feature stuff in m68k.h makes me think it won't solve the problem (if indeed
> there is one).
The CPU feature flags are mostly simply booleans. They ask a question
and you need to answer it for your CPU model. Add a new one if it doesn't
map onto an existing one.
If the questions are answered correctly, then there shuold not be any
fundamental problems. A software managed interrupt stack for 68000-ish
cores would be nice though. :)
--joel
