Context switching
Thu Mar 2 04:01:15 UTC 2000
Is the task both preemptible and timesliced?  Both must be enabled
for timeslicing to work.
FYI dispatching is done at the end of the outermost interrupt.
> "Jimen.Ching" wrote:
> Hi all,
> I have a question about context switching.  I'm looking through the
> code
> and see that a context switch may be attempted in rtems_clock_tick if
> dispatching is enabled.  But rtems_clock_tick is called from inside an
> interrupt handler.  Thus, _Thread_Dispatch_disable_level is always
> greater
> than zero, and the context switch is never done.
> Did I miss something?  I'm trying to use timeslicing, 100 ticks per
> slice,
> but it doesn't seem to work.
> Thanks in advance for any help.
> --jc
> jimen at adtech-inc.com     Adtech, Inc.    (808) 734-3300
