PPP was Re: Webserver Graphics in flash.
Matthew J Fletcher mfletcher at serck-controls.co.uk
Tue Nov 7 16:59:49 UTC 2000
Hi,.
>If you have patches to the PPP please submit them.  The PPP
>was merged in the "something is better than nothing" mode.
I noticed, but i dont have patches, just hacks, that might well
break stuff, (but it seems to work ok). I think it would be much
cleaner to do a proper port of ppp2.4.0.
If anyone wants the code i currently have i can mail it directly
(it does work, but its untested on anybody elses kit).
>Jennifer and I have had discussions about converting the IMFS
>a flash based filesystem.  If you can follow some general
>guidelines, then it should not be that bad to accomplish.
>Basically, it needs to (1) not assume it can write directly
>to memory and (2) go through an interface to manage blocks.
>There probably needs to be caching & scheduling layers to
>avoid conflicts on the device.
My ideas are for a pretty full filesystem, it would provide a proper
abstraction layer in the same way that imfs does (i.e user would just do
read/write etc). I was not going to do any caching i was just going to lock
the
device and have the user re-try (during the erase),..)
But i have got a quite well defined allocation methord. If you could send,..
me the guidelines and and plans you have i will add what i can.
>If you are interested we have prepared a quote for doing
>all this work.  Given a bit of details on what you are
>expecting, we could quickly provide you an estimate.
Err,.. quote ?,.. (i dont know much about the rtems system admitidly)
if you want to mail me privatly about this please do.
regards
Matthew J Fletcher
NPD Firmware
Serck Controls Ltd, Rowley Drive, Coventry, CV3 4FH, UK
Tel: 44 (0) 24 7630 5050   Fax: 44 (0) 24 7630 2437
Web: www.serck-controls.co.uk  Admin: post at serck-controls.co.uk
This email and any files transmitted with it are confidential and
intended solely for the use of the individual or entity to whom they
are addressed. If you have received this email in error please notify
the above.  Any views or opinions presented are solely those of the
author and do not necessarily represent those of Serck Controls Ltd.
Please note that Serck Controls Ltd is able to, and reserves the right
to, monitor e-mail communications passing through its network.
This email has been checked for viruses.  Serck Controls Ltd shall not
be responsible for damage caused by any undetected virus.
