PPP was Re: Webserver Graphics in flash.
Tue Nov 7 18:30:55 UTC 2000
Matthew J Fletcher wrote:
> Hi,.
> >If you have patches to the PPP please submit them.  The PPP
> >was merged in the "something is better than nothing" mode.
> I noticed, but i dont have patches, just hacks, that might well
> break stuff, (but it seems to work ok). I think it would be much
> cleaner to do a proper port of ppp2.4.0.
Quite possibly.  The initialization should be the hard part.
> If anyone wants the code i currently have i can mail it directly
> (it does work, but its untested on anybody elses kit).
If you email it to me or upload it to the ftp site, I will review it
and worst case, put it in contrib.
> >Jennifer and I have had discussions about converting the IMFS
> >a flash based filesystem.  If you can follow some general
> >guidelines, then it should not be that bad to accomplish.
> >Basically, it needs to (1) not assume it can write directly
> >to memory and (2) go through an interface to manage blocks.
> >There probably needs to be caching & scheduling layers to
> >avoid conflicts on the device.
> My ideas are for a pretty full filesystem, it would provide a proper
> abstraction layer in the same way that imfs does (i.e user would just do
> read/write etc). I was not going to do any caching i was just going to lock
> the
> device and have the user re-try (during the erase),..)
> But i have got a quite well defined allocation methord. If you could send,..
> me the guidelines and and plans you have i will add what i can.
See separate post for details.
> Matthew J Fletcher
> NPD Firmware
> Serck Controls Ltd, Rowley Drive, Coventry, CV3 4FH, UK
> Tel: 44 (0) 24 7630 5050   Fax: 44 (0) 24 7630 2437
> Web: www.serck-controls.co.uk  Admin: post at serck-controls.co.uk
> This email and any files transmitted with it are confidential and
> intended solely for the use of the individual or entity to whom they
> are addressed. If you have received this email in error please notify
> the above.  Any views or opinions presented are solely those of the
> author and do not necessarily represent those of Serck Controls Ltd.
> Please note that Serck Controls Ltd is able to, and reserves the right
> to, monitor e-mail communications passing through its network.
> This email has been checked for viruses.  Serck Controls Ltd shall not
> be responsible for damage caused by any undetected virus.
