Posix test suite
Stephan Merker
merker at decrc.abb.de
Mon Nov 13 17:19:18 UTC 2000
Thanks. I wanted to have the RTEMS Posix API on the Posix BSP.
Is there any reason to not support this configuration?
Stephan
----- Original Message -----
From: "Ralf Corsepius" <corsepiu at faw.uni-ulm.de>
To: "Stephan Merker" <merker at decrc.abb.de>
Cc: "RTEMS Mailing List" <rtems-users at OARcorp.com>
Sent: Monday, November 13, 2000 5:16 PM
Subject: Re: Posix test suite
> Stephan Merker wrote:
> > Can anybody give me a hint how to get the POSIX test suite configured.
> > I'm using the following configure options:
../rtems-ss-20001103/configure --enable-posix --enable-networking --enable-c
xx --disable-itron --enable-rtemsbsp= --enable-tests --prefix=/usr/local/rte
> > ms
> > So, both posix and tests are enabled, but the posix tests are not copied
> > into the build directory (neither under Cygwin nor under Linux).
> The answer depends on what you refer to.
> * The posix-BSP (which can be build under Cygwin and Linux) does not
> support RTEMS posix API. Therefore the posix API testsuite (pstests)
> gets disabled if building the posix-BSP.
> * For all other BSPs and targets besides the posix BSPs rsp. unix
> target, your configuration line above would be correct (Though
> specifying --enable-rtemsbsp= isn't necessary -- It is equivalent to
> not passing --enable-rtemsbsp.)
> Ralf
> Ralf Corsepius
> Forschungsinstitut fuer Anwendungsorientierte Wissensverarbeitung
> (FAW)
> Helmholtzstr. 16, 89081 Ulm, Germany Tel: +49/731/501-8690
> mailto:corsepiu at faw.uni-ulm.de FAX: +49/731/501-999
> http://www.faw.uni-ulm.de
