Posix test suite
Tue Nov 14 13:35:05 UTC 2000
Stephan Merker wrote:
> Thanks. I wanted to have the RTEMS Posix API on the Posix BSP.
> Is there any reason to not support this configuration?
Name and .h conflicts between RTEMS and the native UNIX that it is
residing on.  Ian Lance Taylor worked out something on Linux
using the dyanmic loader that avoided this conflict.  I can
forward you this if you want to work on getting it merged.
Ralf.. if/when this is merged Linux would be a unique
unix/posix variant. Any ideas on how to handle this?
> Stephan
> ----- Original Message -----
> From: "Ralf Corsepius" <corsepiu at faw.uni-ulm.de>
> To: "Stephan Merker" <merker at decrc.abb.de>
> Cc: "RTEMS Mailing List" <rtems-users at OARcorp.com>
> Sent: Monday, November 13, 2000 5:16 PM
> Subject: Re: Posix test suite
> > > Can anybody give me a hint how to get the POSIX test suite configured.
> > > I'm using the following configure options:
> ../rtems-ss-20001103/configure --enable-posix --enable-networking --enable-c
> xx --disable-itron --enable-rtemsbsp= --enable-tests --prefix=/usr/local/rte
> > > ms
> > > So, both posix and tests are enabled, but the posix tests are not copied
> > > into the build directory (neither under Cygwin nor under Linux).
> > The answer depends on what you refer to.
> > * The posix-BSP (which can be build under Cygwin and Linux) does not
> > support RTEMS posix API. Therefore the posix API testsuite (pstests)
> > gets disabled if building the posix-BSP.
> > * For all other BSPs and targets besides the posix BSPs rsp. unix
> > target, your configuration line above would be correct (Though
> > specifying --enable-rtemsbsp= isn't necessary -- It is equivalent to
> > not passing --enable-rtemsbsp.)
> > Ralf
> > Ralf Corsepius
> > Forschungsinstitut fuer Anwendungsorientierte Wissensverarbeitung
> > (FAW)
> > Helmholtzstr. 16, 89081 Ulm, Germany     Tel: +49/731/501-8690
> > mailto:corsepiu at faw.uni-ulm.de           FAX: +49/731/501-999
> > http://www.faw.uni-ulm.de
