M-Systems Flash Disk compliance.
angelo at hunterlink.net.au angelo at hunterlink.net.au
Thu Nov 16 02:40:58 UTC 2000
So does RTEMS have a built in RAM filesystem as standard?
>>Hmmm, I originally thought that the DOC was
>>an IDE device;
>No, the Disk-On-Chip is just a standard integrated circuit package that you
>connect to a memory bus.  The usual method of connection is to the ISA bus
in
>a PC architecture.
>>with the wear levelling alogorithm being internal to the
>>chip and provided by a BIOS extension.
>Correct.  The problem comes because you have to make real mode calls to use
>the BIOS extension.  RTEMS runs in protected mode, so to use the BIOS
>extension, you would have to switch back to real mode, make the call, then
>switch back to protected mode.  Could get ugly.
>If you aren't going to use the BIOS extension that gets loaded at boot, that
>is when you need the TrueFFS filesystem code. I think that is called the
>"OSAK," the Operating System Adaptation Kit.  That is provided by M-Systems
>under license.
>-- Chris Caudle
There are those who seek knowledge for the sake of knowledge - that is
CURIOSITY
There are those who seek knowledge to be known by others - that is
VANITY
There are those who seek knowledge in order to serve - that is LOVE
    Bernard of Clairvaux (1090 - 1153)
Home Page
http://users.hunterlink.net.au/~maaaf/
