RTEMS Samples
Ralf Corsepius
corsepiu at faw.uni-ulm.de
Tue Oct 10 08:03:58 UTC 2000
Steven Johnson wrote:
> Is there a configure option to prevent the samples from being built?
> --disable-tests does not do it.
--disable-test disables the testsuite, but the samples get always
built as a means to check the integrity of the preceding built of
RTEMS
> If there isn't one already, and I added a --disable-samples option to
> configure.
Why do you think we need this?
> Where and how do i submit the patch.
Post it to Joel at OARCorp.com or to one of OAR's lists (eg. here)
Ralf
Ralf Corsepius
Forschungsinstitut fuer Anwendungsorientierte Wissensverarbeitung
(FAW)
Helmholtzstr. 16, 89081 Ulm, Germany Tel: +49/731/501-8690
mailto:corsepiu at faw.uni-ulm.de FAX: +49/731/501-999
http://www.faw.uni-ulm.de
