i386 bsp issues
Thu Aug 2 16:30:14 UTC 2001
lange92 at 2067.resnet.uni.edu wrote:
> On Thu, 2 Aug 2001, Joel Sherrill wrote:
> > > ../rtems-4.5.0/configure --target=i386-rtems --enable-posix
> > > --enable-rtemsbsp="pc386"
> > > --prefix=/users/lange92/illinoiscentral/build-i386-coff-rtems
> > > compiles further now, but then it bombs out with the following errors:
> > > ../../../../../../pc386/lib/librtemsall.a(bootcard.o): In function `boot_card':
> > > bootcard.c:108: undefined reference to `bsp_start'
> > Look in startup/Makefile* and remove the -DUSE_INIT_FINI
> This error still remains after making the change. Any ideas on this one?
This is a different error and looks like you are somehow now building
bspstart.o anymore.  You may need to clobber, reconfigure and build
from scratch since you hacked a makefile.  If you did something slightly
wrong, it could have messed up the dependencies in the build tree.
> Many thanks,
> DanL
