i386 bsp issues
Thu Aug 2 21:45:17 UTC 2001
"Aaron J. Grier" wrote:
> On Thu, Aug 02, 2001 at 06:02:07AM -0500, lange92 at 2067.resnet.uni.edu wrote:
> > But the error that I'm staring at is:
> > <rtems-4.5.0>
> > ../../../../../../pc386/lib/librtemsall.a(bootcard.o): In function `boot_card':
> > bootcard.c:108: undefined reference to `bsp_start'
> maybe it's a label problem?  if you're doing COFF, shouldn't that be
> _bsp_start?
All of the code is in C so that should deal with most of the label issues.
And even if it were in assembly, if proper macros were used then it would
not be an issue either.  RTEMS (and newlib) use a SYMBOL macro (or something
similar) to wrap labels.
>   Aaron J. Grier   |    Frye Electronics, Tigard, OR   |   aaron at frye.com
>                        Of course unix clones exist...
>                   How else are unix supposed to reproduce?
