Networking with MVME2307 (actually MVM2400)
tsmith at megaroms.co.uk
Thu Aug 9 14:22:42 UTC 2001
I'm trying to compile the netdemo program from netdemos-4.5.0 using the MVME2307 bsp. I get a warning that RTEMS_BSP_NETWORK_DRIVER_NAME hasn't been defined. It's not defined in the bsp so should I manually define it? What should I define it as? Same for RTEMS_BSP_NETWORK_DRIVER_ATTACH.
I'm guessing this is relatively important as running the program on the board after these warnings are given results in a crash:
RTEMS RELEASE rtems-4.5.0(PowerPC/PowerPC 604/mvme2307) PANIC OpenPic Not found
exception handler called for exception 12
Next PC or Address of fault = 475c
Saved MSR = 3032
R0 = 4758
R1 = 5cf60
R2 = 0
LR = 4758
MSR = 50000
unrecoverable exception!!! Push reset button
Help much appreciated
