problem while linking rtems and chsm
JSuchotzki at de.abb.com
Mon Aug 13 16:29:28 UTC 2001
Hi,
I try to get familiar with rtems. On this way I want to compile an
application.
The application uses the chsm (a "program" to simply implement a state
machine).
For more information chsm see
http://homepage.mac.com/pauljlucas/software.html
When I call make (debug) the following error is shown:
make -f Makefile MAKEFILE=Makefile "ARCH=o-debug" \
"CFLAGS_DEBUG=-Wno-unused -qrtems_debug -qrtems_debug" \
"CXXFLAGS_DEBUG= -qrtems_debug" \
"CFLAGS_OPTIMIZE=-g" \
"LDFLAGS_DEBUG=" all
make[1]: Entering directory `/home/jan/develop/experimental/chsm-pmueller'
test -d o-debug || mkdir o-debug
m68k-rtems-g++ -B/usr/local/rtems//m68k-rtems/efi332/lib/ -specs bsp_specs
-qrtems -g -Wall -ansi -fasm -qrtems_debug -mcpu32
-DPJL_NO_NAMESPACES -I/home/jan/develop/pecos_demo_III/component/inc -I.
-c -o o-debug/main.o main.cpp
In file included from ao.chsm:6,
from main.cpp:7:
AnalogOut.h:52: warning: `class AnalogOut' has virtual functions but
non-virtual destructor
In file included from main.cpp:7:
ao.chsm:112: warning: `class ao::state_mode::state_operational' has virtual
functions but non-virtual destructor
ao.chsm:117: warning: `class ao::state_mode' has virtual functions but
main.cpp: In method `int ObjectManager::initialize(ObjectManager *, int)':
main.cpp:59: warning: control reaches end of non-void function
`ObjectManager::initialize(ObjectManager *, int)'
-c -o o-debug/AnalogOut.o AnalogOut.cpp
In file included from AnalogOut.cpp:2:
AnalogOut.cpp: In method `int AnalogOut::initialize(ObjectManager *)':
AnalogOut.cpp:19: warning: control reaches end of non-void function
`AnalogOut::initialize(ObjectManager *)'
m68k-rtems-gcc --pipe -B/usr/local/rtems//m68k-rtems/efi332/lib/ -specs
bsp_specs -qrtems -g -Wall -ansi -fasm -g -Wno-unused -qrtems_debug
-qrtems_debug -mcpu32 -DPJL_NO_NAMESPACES
-I/home/jan/develop/pecos_demo_III/component/inc -I. -L
/usr/local/rtems//m68k-rtems/efi332/lib -o o-debug/ao.nxe
o-debug/main.o o-debug/AnalogOut.o
/usr/local/rtems//m68k-rtems/efi332/lib/no-dpmem_g.rel
/usr/local/rtems//m68k-rtems/efi332/lib/no-mp_g.rel
/usr/local/rtems//m68k-rtems/efi332/lib/no-signal_g.rel
/usr/local/rtems//m68k-rtems/efi332/lib/librtems++_g.a -Lchsm -lchsm
-L/home/jan/develop/pecos_demo_III/component/inc/lib -lPecosAuxiliaries
-lstdc++
collect2: ld terminated with signal 11 [Speicherzugriffsfehler], core
dumped
make[1]: *** [o-debug/ao.exe] Error 1
make[1]: Leaving directory `/home/jan/develop/experimental/chsm-pmueller'
make: *** [debug] Error 2
Maybe someone knows if there is a general problem with linking chsm to
rtems code.
The error occures only when I try to link chsm. I have attached the
Makefile.
Some data about my system:
Source: Pentium II, SuSE Linux 7.2, chsm compiler 2.4.3,
rtems-ss-20010326
Target: m68k
Thanks in advance
Jan
(See attached file: makefile-for-rtems-mailinglist.txt)
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20010813/bc3a79e8/attachment.obj>
