x86 programming question
Thu Aug 23 18:19:54 UTC 2001
Hi,
On the pc386 BSP, can I make a BIOS int call from protected mode
(easily).  If not, I want to make a bios call in the start16.S code,
store the result and use it later.  This is simply a call to return
the size of memory.  Advice appreciated. :)
