x86 programming question
Erwin Rol
erwin at muffin.org
Thu Aug 23 18:49:03 UTC 2001
On 23 Aug 2001 13:19:54 -0500, Joel Sherrill wrote:
> Hi,
> On the pc386 BSP, can I make a BIOS int call from protected mode
> (easily). If not, I want to make a bios call in the start16.S code,
> store the result and use it later. This is simply a call to return
> the size of memory. Advice appreciated. :)
AFAIK it is done via a int 0x?? and passes the parameters in registers
and the resulets too. A look at the lilo code or the linux kernel start
code might give you some hints.
- Erwin
> Joel Sherrill, Ph.D. Director of Research & Development
> joel at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
