hello_world Only compiles.
    Joel Sherrill
    joel at OARcorp.com
    Mon Aug 27 20:57:25 UTC 2001
Vivek Vaid wrote:
> Hello,
> I have compiled my first "hello world" program, and transferrd it to a
> 486pc through Etherboot. I was very glad, as the manual is very precise.
> But I am not able to compile any other sample programs.
> The env. variable RTEMS_MAKEFILE_PATH is set properly.
> The error I get when i try to compile any other example it :
> /opt/rtems/pc386/lib/include/confdefs.h:1005: #error "CONFIGURATION
> ERROR: No tasks or threads configured!!
> #endif
By default RTEMS configures as few resources as possible.  This error
indicates that you
have not configured any tasks.  The hello world example has something
like this line in it:
#define CONFIGURE_MAXIMUM_TASKS 1
or something like that.  See this URL for details on the confdefs.h
constants:
http://usa.oarcorp.com/rtemsdoc-4.5.0/rtemsdoc/html/c_user/c_user00365.html
> I noticed that, this error should come if one of the #define's is not
> present in c file calling confdefs.h But in all sample programs, it is
> done.
> My directory structure of the sources of examples is.
> /home/src/examples/
> 		/hello
> 		/cxx
> /home/src/hello
> /home/src/net
> 	/netdemo
> I am able to compile Both The Hello Demos (in different
> directories). But not any netdemo, or other example.
> Please let me know, what mistake I am making.
> Do I need to re-compile the full rtems, for each sample program ?
No way.  :)  I suspect you defined it after including confdefs.h.  All
CONFIGURE_
constants must be defined before include the .h file to alter the behavior.
> Thanks a lot.
> Vivek
