Anybody using Windows 98 for RTEMS GNU tools?
Bogic Petrovic boggy at elab.tmf.bg.ac.yu
Thu Aug 30 15:05:19 UTC 2001
yes, but only (without any restrictions) shareware (30 days) but price
and complexity with two box system (Win+Lin) or one with win+cygwin....
this is (I think...) optimal combination for "all in one" concept.
I try also cygwin but i have big problems with debugger (parallel port
driver) , new driver work only with cygwin+W9x, cygwin+RTEMS work well
only with NT....
With vmware I have standard platform (W2k, W9x or WinNT) and virtual,
but classic
RH-7.1 with full linux based network capabilities (DNS, DHCP, TFTP, NTP,
SMB,...)
and full periferal support (parallell port, serial port,...)
Vmware is resources hungry, (256MB + 450MHz box is recommanded for it)
Bogic
Maarten.Kruger at ziton.spx.com wrote:
> Hello,
> Thanks for the advice - is there a free version available?
> Maarten Kruger
> *** Please note my new email address:
> maarten.kruger at ziton.spx.com   ***
> Maarten Krüger
> ZITON (Pty) Ltd
> P O Box 4965   CAPE TOWN    8000   RSA
> Tel +27 (0)21 506 6000   Fax +27 (0)21 506 6100
> Edwards Systems, USA
> http://www.est.net
> SPX, USA
> http://www.spx.com
> Disclaimer:
> The information contained in this electronic mail transmission is intended
> by SPX Corporation for the use of the named individual or entity to which
> it is directed and may contain information that is confidential or
> privileged. If you have received this electronic mail transmission in
> error, please delete it from your system without copying or forwarding it,
> and notify the sender of the error by reply email or call the SPX Help Desk
> at (USA) 215-293-2811 so that the sender's address records can be
> corrected.
>                     Bogic Petrovic
>                     <boggy at elab.tmf        To:     Maarten.Kruger at ziton.spx.com, rtems
>                     .bg.ac.yu>             <rtems-users at OARcorp.com>
>                                            cc:
>                     01/08/30 11:57         Subject:     Re: Anybody using Windows 98 for
>                     AM                     RTEMS GNU tools?
> try vmware (http://www.vmware.com)
> My target is MC68360+RTEMS and remote debugging via BDM (attached at
> LPT1)
> also work well. My host is Win2000AdvSrv+vmware+RH7.1.
> Bogic
> > Good day,
> > The getting started .pdf manual states that Windows 95 is not suitable
> for
> > compiling and debugging RTEMS in Cygwin...  Since the document is quite
> old
> > - I was wondering if this is still true?  I am using Windows '98 and
> would
> > like to use it just to get started with RTEMS until I install Mandrake
> 7.2
> > (think this is a good choice?) ...  I would still like to use Windows '98
> > for other work (can't dual boot all the time)...
> > Is anybody successfull using all the GNU tools in Windows 98 for RTEMS?
> > Can you please give me tips for getting started - had problems with
> > Cygwin...
> > thanks
> > Maarten Kruger
