PC-104
rwas mc68332 at yahoo.com
Sat Aug 18 07:05:59 UTC 2001
That was it. Thank you kindly
Robert W.
Dynacs Engineering
Joel Sherrill wrote:
> rwas wrote:
> > I'm using rtems with pc104. I am rather green on rtems however. I have
> > successfully compiled and run
> > two of the netdemos and hello world. My current problem is that rtems
> > won't use the serial port as the
> > console device.
> My understanding was that you modified the setting of a couple of
> variables in
> pc386/console/console.c to accomplish this.
> * Possible value for console input/output :
> *      BSP_CONSOLE_PORT_CONSOLE
> *      BSP_UART_COM1
> *      BSP_UART_COM2
> * Note:
> *   1. Currently BSPPrintkPort, cannot be assigned to COM2,
> *      it will be fixed soon.
> *   2. If both BSPConsolePort and BSPPrintkport are assigned
> *      to same serial device it does not work that great
> int BSPConsolePort = BSP_CONSOLE_PORT_CONSOLE;
> int BSPPrintkPort  = BSP_CONSOLE_PORT_CONSOLE;
> /* int BSPConsolePort = BSP_UART_COM2;  */
> int BSPBaseBaud    = 115200;
> > My processor board is the Jumptec MOPS/586..
> > My main issues currently are getting or writing a device driver for
> > ethernet chipset (Crystal CS8900)
> It has a libchip driver so all you should need is the glue to the
> particular configuration.
> Chris Johns <ccj at acm.org> submitted this a while back.
> > and drivers for a DtoA board as well as a Synchronous Serial Interface
> > board.
> OK those aren't in the tree.  If they are for off-the-shelf boards, we
> all would be happy to see
> them in the tree.
> And I hope it goes without saying that custom driver development is one
> of OAR's
> many RTEMS related services.
> > Robert Wasierski
> > Dynacs Engineering
> > Eric Norum wrote:
> >> I apologize in advance if this is a FAQ, but is anyone out there in
> >> RTEMS-land using PC-104 SBC's?
> >> If so, with what processor?  Using what BSP?
> >> Thanks,
> >> Eric Norum                                 eric.norum at usask.ca
> >> Department of Electrical Engineering       Phone: (306) 966-5394
> >> University of Saskatchewan                 FAX:   (306) 966-5407
> >> Saskatoon, Canada.
> > _________________________________________________________
> > Do You Yahoo!?
> > Get your free @yahoo.com address at http://mail.yahoo.com
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel at OARcorp.com                 On-Line Applications Research
> Support Available                (256) 722-9985
Do You Yahoo!?
