flash file systems
Fernando RUIZ CASAS correo at fernando-ruiz.com
Thu Aug 30 21:37:29 UTC 2001
> -----Mensaje original-----
> De: Brett Swimley [mailto:brett.swimley at aedinc.net]
> Enviado el: miércoles, 29 de agosto de 2001 23:53
> Para: 'RTEMS'
> Asunto: flash file systems
> Hello all -
> I'm wondering about the status of the Non-Volatile Memory Driver
> for RTEMS.
> My Latest documentstation states "There is currently only one non-volatile
> device driver inclued in the RTEMS source tree and it does not adhere to
> this device driver model."
> My questions are:
> 1) Is there a more recent Non-Volatile (esp Flash memory) driver available
> for RTEMS.
> 2) If so, can a file system be mounted using this driver?
> Thanks,
Attached two drivers ready to be used in rtems (Only the physical access
needs be changed).
Perhaphs not the best driver but a driver for e2prom & flash.
/dev/fla & /dev/e2p
After this you can include the sourecs into a BSP or into USER level
application.
Don't hesitate to ask me if you have any question.
Fernando RUIZ CASAS
home: correo at fernando-ruiz.com
work: fernando.ruiz at ctv.es
> Brett Swimley
> Sr. Design Engineer
> Advanced Electronic Designs, Inc.
> ph: 406-585-8892
> fax: 406-585-8893
> www.aedinc.net
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20010830/5707f258/attachment-0003.obj>
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20010830/5707f258/attachment-0004.obj>
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20010830/5707f258/attachment-0005.obj>
