Another gensh2 questions
Radzislaw Galler
rgaller at ET.PUT.Poznan.PL
Tue Jan 30 13:41:03 UTC 2001
Hi,
I have some questions:
1. What are sections 'monvects' and 'monram' and why they need so much
space? Looking into *.map file of an application there is nothing in
these sections. It wastes half of RAM on my EVB.
2. I am hacking the console driver in gensh2 to use termios (with
success - thanks Fernando!). The question is about registering files in
system. The console driver should be the first entry in drivers table
(otherwise it doesn't work - don't know why; system uses driver with
major=0 which is simple SCI driver in current snapshot). When I want to
link /dev/console to /dev/sci0 (serial port) it has to exist. If I
register it in console_initialize() it will have major number 0. It
makes no difference to driver routines because the use only minor number
but right now I have /dev/sci0 with major=0 and minor=0 and /dev/sci1
with major=1 and minor=1. Does it make sense? Is it dangerous? I did not
look into another bsp's but maybe there is no sense to make separate
drivers for console and serial ports. This wouldn't be an issue if the
console worked independently from the location in the driver table.
Regards
Radek
