i386/pc386 COM2 Serial Port Problem - Solved
Mike Siers
mikes at poliac.com
Tue Jul 24 16:07:46 UTC 2001
Hi,
I found the problem, it was with my task driven I/O patch to the
c/src/lib/libbsp/i386/shared/comm/uart.c file. I have a cut/paste
error in the BSP_uart_termios_read_com2 function. The first
block of code in the function was using the BSP_UART_COM1
constant value instead of BSP_UART_COM2.
Joel, do you want a patch file for this? I would like it to get fixed
in the next snapshot.
Sorry for the new bug,
Mike Siers
-----Original Message-----
Sent: Monday, July 23, 2001 2:48 PM
To: rtems-users at oarcorp.com
Subject: i386/pc386 COM2 Serial Port Problem
Hi,
I have program that works perfectly when I use the COM1 serial port.
If I switch the application to use COM2 instead of COM1, it does not
work. It does not look like any data gets transmitted out over the port.
I have both the tty drivers in my device driver table and I see the device
initialized message for both COM ports. I also have the number of
file descriptors set to 8.
Has anyone seen this problem? My application requires that I use both
COM ports. This test application is only using one port at a time but it
does not work with COM2. I am using the latest snapshot 2001/07/12.
Thanks
Mike Siers
URL: <http://lists.rtems.org/pipermail/users/attachments/20010724/19bb7309/attachment.html>
