Will RTEMS run on my board?
Mont Pierce
Mont at MonteSoft.com
Tue Jul 10 22:08:43 UTC 2001
I don't have an MBX8xx board, but I do have a FADS860 board I could
use to get started. Does anyone have a BSP for the FADS860?
Thanks,
Mont
----- Original Message -----
From: "Joel Sherrill" <joel.sherrill at OARcorp.com>
To: "Mont Pierce" <Mont at MonteSoft.com>
Cc: <rtems-users at OARcorp.com>
Sent: Tuesday, July 10, 2001 11:43 AM
Subject: Re: Will RTEMS run on my board?
> Mont Pierce wrote:
> > Can anyone give me an idea on how feasible it would be to implement
> > RTEMS in a custom MPC860SAR board with only 2mb Flash and
> > 4mb SDRAM? I need TCP/IP stack with telnet server and tftp server
> > over ethernet. I also need some(64k) of the 2mb of Flash to store non-
> > volatile config data.
> Ignoring the telnetd and snapshot issue, the 860 is a well supported
> target with multiple users. There are example BSPs for the Motorola
> MBX8xx series of board and the custom eth_comm BSP. I can offhand
> think of a few users with custom 860 boards. The 8xx support is mostly
> in the form of shared/libcpu code so is easier to create new BSPs with.
> > Thanks,
> > Mont
> Joel Sherrill, Ph.D. Director of Research & Development
> joel at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
